Question about Kenmore 24 in. 16182 / 16189 Built-in Dishwasher
I have a Kenmore 587.16182401 Dishwasher. It fills with waer and drains ok, but the is no washing action or any kind. It just sits there during the wash cycle. The soap ends up in a glob in the bottom tray.
Posted by Mark David on
5 Related Answers
Anonymous
  • 209 Answers
SOURCE: Water doesn't drain
simple one this, just clear out the waste pipe and the inside food filter and the outlet pump, also check the outlet where the pipe goes (under the sink?) its a simple blockage somewhere, if i have helped rate me, and work safe remove the plug etc
Posted on Sep 16, 2007
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Build up in dishwasher
powder works best in d/w. breaks down better in hot water application.
Posted on Oct 26, 2008
Anonymous
  • 132 Answers
SOURCE: The soap dispenser on my bosch dishwasher doesn't open
it is agood manual solution but if you want to rea ly fix that there is {an electrical order reach at suitable time to open the dispenser it come from electronic circuit to elecronic lock which catch the
dispenser so one of those parts may be fualty
Posted on Jun 09, 2009
GM Elec
Bruce Bracey
  • 1000 Answers
SOURCE: the soap isn't coming out of the soap dispenser
I had the same problem once. Make sure nothing is stacked in front of the soap dispenser when you close the door. Slowly close the door and follow the soap dispenser to make sure it has enough clearance to open.
Let me know how it goes.
Regards,
Posted on Jul 19, 2009
drallim
  • 4088 Answers
SOURCE: during dishwasher cycle soap dispenser won't open
Remove the door inner panel and check the dispenser door solenoid for free movement along with the latch mechanism. Water can enter through a leaking seal and corrode the interior of the solenoid causing sluggish or non-functioning of the latch. Change the solenoid if it seems sticky and can't be fixed by cleaning the bore and plunger (don't apply oil as it will gum up the operation after a while).
Posted on Oct 18, 2009
Some water is leaking under the dishwasher and on the kitchen floor during the end of the wash cycle.
Does it leak during pump-out only?
If so , must be drain hose .To see everything,remove kick plate to isolate leak. Check hose connections. Fill and drain and observe.Or run a whole cycle with kick plate off to find leak.
Good luck
Aug 15, 2011 | Kenmore 24 in. 15689 Built-in Dishwasher
Water and draining ok, washing not.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 03, 2010 | Kenmore 16522 Built-in Dishwasher
The dishwasher will not drain.
Check your main drain system. Remove the drain hose from that end and discharge them in a bucket. Try a new wash an if the m/c drain system is ok, it will discharge water in the bucket.
Check the house main drain for clogging at the hose connecting end.
May 25, 2010 | Bosch SHU5315UC Dishwasher
Dishwasher does not fill
Double check that your water supply line is not kinked.
This sounds like a bad fill valve. If you have hard water and most everyone does after a few years the valve will quit working properly and will fail in one of 2 ways a slow or no fill or it will not shut off completely.
I hope this helps if I can help with anything else please let me know.
Apr 15, 2010 | Kenmore 24 in. 16003 Built-in Dishwasher
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher, water not going through the jets
when you hear the motor running during the wash cycle, check to see if the washer is actually draining instead of washing. this would indicate a stuck open drain valve. (the same motor/pump that washes the dishes, also drains the unit)
Feb 07, 2009 | Kenmore Dishwashers
Dishwasher was making whirliing noise during wash, now no wash, only fill and drain
there is a #10 torx screw holding that cover down.do not drill it out. after you take it off you can tell if the chopper is broken.be careful for broken glass.
Oct 17, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
DIshwasher doesn't drain or fill
Hello annie8866,
First off.. unplug power and then reapply power to it for a little while to see if a power reset will put it back in the proper sequence.. next, check inside the base for a drain inlet and a filter/screen and clean anything you see out of it.. Then try cycling it without dishes to see if it will run thru a cycle and drain properly.. Its ok to add a cup or two of white vinegar during the wash process to remove byproducts of the wash from the inner components.. Make sure the drain hose is not clogged or kinked up.. Try these things and get back to me if it is still misbehaving..
Sep 29, 2008 | Magic Chef CDB6100 Built-in Dishwasher
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore 24 in. 16182 / 16189 Built-in Dishwasher Logo
141 people viewed this question
Top Kenmore Dishwashers Experts
Ron Rak
Ron Rak
Marvin
Marvin
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
