Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Kenmore elite dishwasher, does not get the dishes wet
Kenmore elite dishwasher, goes through the various cycles; fills, drains, heats, but never sprays water through the impeller to wash the dishes
Posted by gus_espinoza on
  • Anonymous Mar 27, 2014
    This seems to happen no matter which washing cycle I use.
Anonymous
  • 1,891 Answers
Sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Posted on Nov 22, 2009
1helpful
Kenmore dishwasher: Pre-wash cycle is too short: fills with water, runs for only one second, and then drains. The rest of the cycle is fine; the dishes get clean.
Pre-wash may be compromised and a new power circuit board may be needed.
My advice: As long as the other cycles are accurate and work as usual; Pre-wash in your sink (spray off waste material) before you place the dishes in the washer and commence cleaning. Its best to wash off food and other material before washing in the machine to avoid clogging the drains and pump.
2answers
Kenmore elite dishwasher-model 13193k902-water isn’t getting sprayed up from the bottom. I first noticed a metal tab from the heating element clamp was bent up blocking the rotary sprayer. I bent it back...
not sure if you have a plastic arm that spins under or over the dishes, but mine did. I noticed that the holes where the water came through were plugged by calcium and food. I took a sewing needle and cleaned out the holes. It then sprayed water again. Hope this helps.
My kenmore dishwasher doesnt heat during drying
The heating element is burned out or the heating circuit is fubar.
Should the inside of the elite dishwasher still be wet at the end of the cycle?
Martha,
If you are talking about having a small amount of water down in the bottom of your dishwasher, that is normal. There is a sump down there that needs to have water in it. If you are talking about having water on the walls, that is probably just condensation from the cycle when you run the heater. Try cracking the door after the cycle is done to let the excess steam out of the dishwasher and that may eliminate the water on the walls. Hope this helps!
My Kenmore Elite dishwasher did not drain the water out of the bottom after the dishes were washed last night. Could I possibly have pushed a wrong button to keep it from draining, or do I have a problem?...
Yes , If the program controller has hung it would have skipped the drain cycle. So try to redo the cycle and see if the drain works, is not check the program controller and the drain valve/pump.- if there is food particles that have clogged and blocked.
The dishwasher is not cycling. It does not wash the dishes and it does not drain the water.
Welcome to FixYa.
Can you explain more details, are you implying the unit fills with water, that it has power on the panel and you can select a cycle and nothing happens ?
Just need a little more info so i can be specific to your dishwasher.
Thanks for choosing FixYa. Please reply so we can move forward.
Regards,
Macmarkus :)
Kenmore elite dishwaher 1646 not cleaning dishes.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
jklfryyr
2helpful
My new Kenmore Elite panel ready dishwasher leaves wet
You need only enough space so the door does not rub when opened. If the unit is too far back under the cabinet the countertop (if wood) can be damaged by the exhausting moisture. The dry feature on the newer models is just as you describe. The moisture from the hotter dishes evaporates and is condensed on the cooler walls and door of the wash tub. Dry dishes wet tub is normal.
Eric
2helpful
3answers
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
