20 Most Recent
Leeson Reversible Electric Motor 3/4 HP Questions & Answers
I have Delco Model 2J2424r1, frame 56R, Series
If it has 9 leads and is a 240/480 volt motor the 1and 7 go to line 1. the 2 and 8 leads go to line 2 and the 3 and 9 leads go to line 3. the 4 5 and 6 leads are hooked together with a wire nut. To reverse rotation simply reverse any 2 of the line leads.. Prairie Dog........
11/15/2012 12:07:18 AM •
Leeson...
Answered
on Nov 15, 2012
What happens to a 240v
It will not run. With only one wire hooked to both leads there is no potential and no place for the current to flow to. electric bruno.
6/17/2011 3:36:15 AM •
Leeson...
Answered
on Jun 17, 2011
I have a 3/4 HP motor installed on my porch
it is possible that the start/run winding is open cicuit or cable connections via the capacitor you mentioned , is it distorted , any sign or leakage . as it is on a stair lift the motor has to be reversed , is the reversing switch intact.
Ian c
1/27/2010 8:43:45 PM •
Leeson...
Answered
on Jan 27, 2010
How much should good scaffold brick guards cost me?
These should be expensive, but they are nothing of the sort. You can pick up quality scaffold brick guards online for as little as £3.99. I use a company called
BrikGard because they use 100% recycled plastic scaffold brick guards. I like to be as environmentally friendly as possible without compromising quality or increasing the purchase cost too much. Given that their brick guards are so cheap and made from 100% recycled plastic, I feel safe using them. Also, anyone working on-site should consider using a brick guard because it offers that extra layer of peace of mind so you can get focused on the job without worrying about things like falling debris coming down and striking you. For affordable scaffold brick guards, I would check out BrikGard.
