Question about Leeson Reversible Electric Motor 3/4 HP
What happens to a 240v electric motor if you hook up the same phase 110v to each of the 2 lines
Posted by skanbrowns4 on
prairie dog
    New Friend:
It will not run. With only one wire hooked to both leads there is no potential and no place for the current to flow to. electric bruno.
Posted on Jun 17, 2011
Trying to wire a single phase 1HP motor to a standard hot, neutral, ground plug. J10 Black ----] 2 White----] low volt line T4 Yellow---] P2 Brown----] T3 Orange---] T5 Red--------] P1 P
didnt specify to much --generic answer -- sounds like hooking up a heating or cooling unit black and white should be your line voltage use a meter to test your black and white line for 110v if motor is 110v the low voltage lines are control or switch lines that dont go to motor they usually go to a thermostat or transformer
May 04, 2017 | Cars & Trucks
What are the electrical requirements; 110V and/or 240V??
the voltage required is stamped on the plate on the electric motors
it will read
voltage
phase
current( watts)
duty cycle that plate tells you what the motor needs to run
Jun 23, 2016 | Jacuzzi Home
I am working with a Dayton 2YU39. The name plates states that it has to be powered by 208 volt system. There's a 3-phase panel and a single-phase panel. The 3-pahse panel L1 to ground is 118 volts. L2 is a...
Here's what I think but you will have to check it out...
The fan motor in the 39 heater is a 120V fan there fore it cannot be hooked to the 240 which potentially could have the high (wild) leg as one of the fan legs...
The 240V 36 unit probably has a 240v fan motor....
Now if you were to make sure that the leg that fed the motor was a 120V to ground leg then you will be okay...
Hope you understand where I was going with this...
heatman101
Oct 27, 2010 | Dayton 2YU44 Electric Heater
How to conect 3 phase motor 9 yellow wires from t1 to t9
There is no neutral on 3 phase. They are all power wires. If you try hooking up a 3 phase motor to single phase power it won't work.
May 23, 2010 | Omega 5hp 1740RPM 184TC Frame 230 Volts...
I have a GE Profile Harmony Dryer. No Power. 240v, 110v, 110v at the outlet but soon as I plug in the dryer I see 240v, 110v, 0v. Is the problem in the dryer or the power outlet on the wall?
Its not really clear to me where your measuring once you plug in the dryer, but all phases are measuring the correct voltage before, it appears you have an open circuit once you plug the dryer in. Now a dryer is 2 phase, so I would check all of your wiring connections, I would also check your circuit breaker and try swapping it out with a new one(as a last resort). Do some experimenting. In a dryer the heating elements are the only thing that runs on the 240V power. I would swap the hot leads in the dryer and see if any of the electrical components come on. Also try testing the continuity on your dryer plug wires to make sure there isn't a break in them (which can be proven by swapping the leads because now the same lead will read 0V on the other terminal).
Mar 31, 2010 | GE Profile Harmony DPGT750EC Electric...
I have a question, why there are 2 voltage in American market? where uses 110v, and where uses 250v? We are a manufacturer of power cords , power supply cords, we really want to know the difference ....
110V is our common household current and 220v is used where heavier voltage is needed, like ovens, stoves, clothes dryers, air conditioners, electric water heaters, arch welders, etc.
Dec 18, 2009 | Computers & Internet
Bought LG DLE2532W Dryer it in Canada, need to use it in Europe
For to use it with a 220/ 240vac system,you will need to convert 110vac 60hz/to240vac 50 hertz single phase therfore your transformer should have this rating,also it has to be able to handle up to 3kw or 3000watts in power, maybe just as cheap buying a new drier....
Nov 28, 2009 | LG DLE2532W Electric Dryer
I have a Kenmore Elite HE3 dryer model # 110.8483220. It has no power. We tested the plug and it tests for 110V of power, and the wire connection at the top of the dryer (on the outside) has power. But...
Your dryer is electric. This means it needs 2 electrical phases (hot wires) and one neutral to wor. If you measure 110v across 2 phases - one of them is out.
Unplug the dryer. Find the double breaker for your dryer on the breaker panel.
Pull breaker to the off position hard (do not overdo it,as you can pull the breaker out), and then back to on position.
Check voltage between the two phases, it should read 220-240v. Check the voltage between each phase and the neutral (middle prong), should read 110-120v. If you don't get these readings - call electrician.
If you get the proper voltage, plug the dryer back in. If it does not work - Dryer needs repair. Likely a thermal fuse is blown or problem with power wiring inside.
Oct 13, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Using dryer in 220V country
There are two systems in use in the states
110v dryers are available that fit a standard 11v 15a socket
110/220v fit the oversize 'dryer' sockets, and they are two 110v phases 90 degreees apart
the motor runs of a single phase 110v.
there is 220v between the 'outside', the active lines of the two phases, at any time, but it is not useable to provide mechanical power as a single service, due to the complicated shape of the wave form when you add out of phase voltages together, but is ok to drive the heaters, they have no mechanical efficiency requirement
A 2 phase 110v heater it means 3kw can be supplied without a 30 amp circuit
but it becomes difficult to use a single phase 220-240v transformer to provide 2x110v 90degree 2 phase current unless you specially buy one in. .
High power applications in 220-240v are generally supplied by 415v 3 phase 60deg supplies,
Any transformer would be onsellable at the end of your posting, to your replacement, who would doubtless be in the same boat as you, with a heap of 'stuff' that needs to run.
UK Aus NZ may be sources of transformers, or dryers to suit.
check with Australian UK NZ suppliers as well as local Indian ones, as those countries are also nominal 240v single phase home suplies and they may have (1) the dryer, or (2)the transformer to suit the 110 2 phase dryer
Sep 10, 2008 | Kenmore 62602 Electric Dryer
240v electric motor
Reducing the voltage is what you want to do -- this will effectively reduce the speed, without creating an annoying hum.
That said -- 110v is too low. Start higher. Half the voltage doesn't equal half the speed.
May 10, 2008 | Hampton Bay 24002 Ceiling Fan
Open Questions:
See all Leeson Reversible Electric Motor 3/4 HP Questions
Leeson Reversible Electric Motor 3/4 HP Logo
165 people viewed this question
Top Leeson Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Leeson Tool and Hardware - Other Expert? Answer questions, earn points and help others
