Question about Leeson Reversible Electric Motor 3/4 HP
I have Delco Model 2J2424r1, frame 56R, Series A84, phase 3 electric motor. What is the wiring diagram to run it under 230VAC?
Posted by lemoore1960 on
prairie dog
    New Friend:
If it has 9 leads and is a 240/480 volt motor the 1and 7 go to line 1. the 2 and 8 leads go to line 2 and the 3 and 9 leads go to line 3. the 4 5 and 6 leads are hooked together with a wire nut. To reverse rotation simply reverse any 2 of the line leads.. Prairie Dog........
Posted on Jun 17, 2011
  • ASHKII MAINT. Nov 15, 2012
    I tried this and didn't work. I was working on a Crown Triton Motor. Got the motor spinning when I hooked L1(1,7,4) - L2(2,5,8) - L3(3,6,9) but it overheated the thermal unit. The wiring diagrams that came with the motor aren't any help either.
How to reverse rotation of single phase, 1/2 HP, 110V electric motor.
Changing the "polarity" of the start winding by swapping the wires over should reverse the direction. Lots of online motor-related generic and manufacturer information is available.
Feb 16, 2015 | Air Tools & Compressors
Can i run a english 3 phase compressor on french 3 phase
I've done it the other way around. A European motor on North American system. The voltage slightly varies and they are 50hz instead of our 60hz. It will just run a little faster/slower than it should. If that is not an issue you should be fine. It probably wouldn't hurt to double check with a qualified electrical contractor in your area.
Nov 11, 2014 | Ingersoll Rand - Rand Type - 30...
How do I reverse a three phase electric motor?
Reversing rotation of 3 phase motors:
CAUTION: Before attempting any repair of electrical equipment verify the power is disconnected to the device.
CAUTION: Three phase motors could potentially be controlled by frequency control systems. It is recommended a trained electrician perform repairs to any electrical system. In particular, consult a trained electrician if the system includes a frequency control system.
Most 3 phase motors can reverse rotation simply by swapping any 2 of the 3 phase wires. A typical 3 phase wiring circuit will include a safety ground wire (usually green) and 3 phase wires, often designated A/B/C, or 1/2/3, or color coded to distinguish each. By swapping the terminal connection of any 2 of the three phase wires, for example, 1 & 2 or 2 & 3 or 1 & 3, but leaving the third phase wire unchanged will reverse the rotation of most motors.
Jun 12, 2014 | Hayward 1.5hp Pool Pump Motor Motor A O...
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
How do I wire a three phase electric motor to 110 plug
You can't run a 3-phase motor on 110V unless you use a 3-phase inverter. Depending on the size of your motor, these will probably run you around $150 for the least expensive type. Take a look at--- http://americanrotary.com/static-phase-converters.html
Jul 24, 2010 | Electric 1HP Century Single Phase Extra...
How to conect 3 phase motor 9 yellow wires from p1
Connect t4,t5,t6 together. Connect t1,t7 together for line 1. Connect t2,t8 together for line 2. Connect t3,t9 for line 3.
May 23, 2010 | Omega 5hp 1740RPM 184TC Frame 230 Volts...
I bought a new electric motor ml7112 series and
does it have capacitors on the motor (humped covers on top) If not then it may ot be a single phase. also on the motor name plate or on the inside cover of the connector box it should have wiring diaphragm that will tell you how to wire the motor, single phase motor will show 2 line connections and a three phase will show 3 line connections,,, line connections are represented by L-1 L-2 L-3 these mean incoming power.
Jan 24, 2010 | Electric Air Tools & Compressors
Open Questions:
See all Leeson Reversible Electric Motor 3/4 HP Questions
Leeson Reversible Electric Motor 3/4 HP Logo
232 people viewed this question
Top Leeson Tools & Hardware - Others Experts
john h
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Leeson Tool and Hardware - Other Expert? Answer questions, earn points and help others
