Question about Leeson Reversible Electric Motor 3/4 HP
Replacing a 220-volt motor on a boat lift with a Leeson A4C17H4H... and its SEVEN wires are all yellow (T8, T2, T3, P2, P1, T4, and T5) which I need to connect to FIVE wires coming in (green, red, orange, black, white.) Obviously several need capped off... but I don't know which! I have pages of notes on what comes from where, but I'm thinking there's probably standardization here and I just don't know it. My usual level of electrical expertise is practical only-- I can replace a light switch or fix a vacuum cleaner cord. Help!
Posted by Angela on
Trying to wire a single phase 1HP motor to a standard hot, neutral, ground plug. J10 Black ----] 2 White----] low volt line T4 Yellow---] P2 Brown----] T3 Orange---] T5 Red--------] P1 P
didnt specify to much --generic answer -- sounds like hooking up a heating or cooling unit black and white should be your line voltage use a meter to test your black and white line for 110v if motor is 110v the low voltage lines are control or switch lines that dont go to motor they usually go to a thermostat or transformer
May 04, 2017 | Cars & Trucks
Wiring a smith and jones 1 hp electric motor for 220. The diagram is not very helpful. I have a red and black hot lead and a white neutral. Where do they all go? I want to make the motor go ccw.
Ok from what I read on the diagram take one lead to P1 cap of P2 T3 T8 and T2 are together and T4 and T5 are put to the second lead
If you want to change direction exchange T5 and T8
Feb 11, 2017 | Smith Pool & Spa
Which is the right partner of T1? IS THE T7? OR THE T4/ OTHER T2.IS THE T8 OR THE T5?
One needs to know what the voltage and phase(1 or 3) the unit is and what the power supply is.
Apr 12, 2015 | Hobart H600 Stand Mixer
I need ang diagram for hobart mixer 9 out wire T1/T2/T3 AND T4/T5/T6, T7/T8/T9 which is the right partner of t1/t2/t3???
Having 9 wires means it is a 3 phase motor.
For 220 to 240 Volts - L1, T1 and T7 go together. L2, T2 and T8 go together. L3, T3 and T9 go together. T4, T5 and T6 go together.
For 440 to 480 Volts - L1 and T1 go together. L2 and T2 go together. L3 and T3 go together. T4 and T7 go together. T5 and T8 go together. T6 and T9 go together.
Apr 12, 2015 | Hobart Food Mixers
Need to know what wire goes to were..on a smith & jones modle 67841 compresser motor..p1 p2 t2 t3 t4 t5 t8..to what wire black white green
Hey guys, this motor is reversible. I have it wired to turn clockwise(according to diagram),
green to ground;
L1 (black) to P1;
L2 (white) to T2-T4-T8;
P2-T3-T5 together .
When I plug it in, the motor turns counter clockwise and the on/off switch does not work. How do I fix?
Oct 27, 2012 | AO Smith A O Smith Motors Centurion 1.5hp...
How to conect 3 phase motor 9 yellow wires from t1 to t9
There is no neutral on 3 phase. They are all power wires. If you try hooking up a 3 phase motor to single phase power it won't work.
May 23, 2010 | Omega 5hp 1740RPM 184TC Frame 230 Volts...
How to conect 3 phase motor 9 yellow wires from p1
Connect t4,t5,t6 together. Connect t1,t7 together for line 1. Connect t2,t8 together for line 2. Connect t3,t9 for line 3.
I NEED TO REWIRE A DOERR LR22132 ELECTRIC
The green should be connected to the chassis, it is ground.
There should be a wiring diagram on it to tell you how to do this, but if not:
There may be T-leads on the motor labeled
P1, P2, T3,T4,T5,T8
P1-L1(black wire)
P2-cap/tape don't use.
T2,T3, and T5 wire nut together
T4,T-8 wire nut together with L2(white)
The power leads will be coming from your switch box on the compressor body itself. Don't wire the 220v directly to the motor, you replace the leads where the first motor was connected on the cutoff switch. There will be only 2 leading from the switch to the motor.
Mar 24, 2010 | Plumbing
Need wiring diagram for 3 phase electric motor
motor leads on a three phase are T1, T2, T3, T4, T5, T6, T7, T8, T9. for high voltage [480] L1 to T1, L2 to T2, L3 to T3, connect together and tape - T4-T7, T5-T8, T6-T9. For LOW voltage [240] L1 to T1 & T7 & tape, L2 to T2-T8 & tape, L3 to T3 & T9 & tape. T4-T5-T6 together and tape.
Oct 20, 2009 | Saws
Open Questions:
See all Leeson Reversible Electric Motor 3/4 HP Questions
Leeson Reversible Electric Motor 3/4 HP Logo
136 people viewed this question
Top Leeson Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Leeson Tool and Hardware - Other Expert? Answer questions, earn points and help others
