20 Most Recent Sony Handycam HDR-CX12 Flash Media Camcorder Questions & Answers
0answers
2answers
How to charge a EFORCE FH50 Compatible Battery
Its appealing simple; Probably you will be accepting sony handcam charger accepting a cable thats declared to fit into ur camcorder and again allegation the battery. For charging the EFORCE FH50 battery, you just allegation to admit that the of the aforementioned cable anon into the battery(DC-IN slot) and bung ur charger into the bank socket. It commonly takes 135 mins to absolutely allegation the battery. Once answerable the LED at tthe DC-IN aperture will about-face off. (During charging its yellow)3_27_2012_9_39_48_am.gif
3/27/2012 9:40:15 AM • Sony Handycam... • Answered on Mar 27, 2012
4answers
Hi there, I have the sony
I'm sorry for the difficulties you're experiencing as the Internal Memory of the Camcorder is not working. Based on the information you have provided, it appears that the Internal Memory of the Camcorder is corrupted. Since you're not able to format the Internal Memory, please follow the below troubleshooting steps and check the operation.
1. Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder. 2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds. 3. After 2-3 seconds has elapsed, release the RESET button.
You can locate the reset button from the below picture.
2. Perform a manual power reset by following the steps:
1. Turn off the camcorder. 2. Disconnect AC power adapter. 3. Remove the battery pack. 4. Move the POWER switch to the CAMERA position for 15 seconds. 5. Move the POWER switch to the OFF position. 6. Reconnect the AC power adapter or reinsert the battery pack. 7. Turn on the camcorder.
Remove the Memory card from Camcorder, connect it to a computer and check whether the Internal Memory is recognizing there. If recognizing, first format using Computer and then format using the Format option in the Camcorder.
If the issue persists after following all the steps service will be required. You can find repair information and initiate service at:
http://www.fixya.com/repair
Thanks for understanding. Please let me know if you require any clarifications.
8/13/2011 8:36:44 AM • Sony Handycam... • Answered on Aug 13, 2011
This camcorder does not record video; it won't format memory card
do you get any kind of error code?what type of memory stick are you using?how big is the ms capacity?may need to try using a diff ms or try using ms with diff devices.if diff ms works fine.may need to format ms using computer first (using card reader if available) and camcorder last.may need to reset camcorder (make sure cam is on when you press the reset button.hope this works.thanks :)
3/13/2010 3:09:32 AM • Sony Handycam... • Answered on Mar 13, 2010
2answers
Sony CX-12 Camcorder gives message when memory stick inserted
Hi!
This is a feature and not a defect of the CX-12 that reminds the user that the memory stick inserted might not be able to record the data from the camera effectively. HD video requires a memory stick with a relatively fast data read/write speed, and the CX-12 recommends not using any other stick that is not Mark 2.
Fortunately, though, as you have found out, it does not affect the camera's ability to record in non-Mark 2 sticks.
Hope this helps!
12/22/2009 12:38:47 AM • Sony Handycam... • Answered on Dec 22, 2009
Sony DCRA-C162 Camcorder. I need a replacement battery for the DCRA-C162. Does anyone know where I can get one?
Question edited for clarity, add full 'make model (what it is)'. Question moved from Cars and Trucks category. Searching for your manual keeps bringing up this manual https://www.sony.com/electronics/support/res/manuals/2698/26988801M.pdf Looking at that manual Page 16, it states the battery pack as 'NP-FP50', and that turns up batteries for $15. https://www.google.com/search?q=NP-FP50 ..
11/20/2023 12:02:19 AM • Sony Handycam... • Answered on Nov 20, 2023
Sony Handycam CCD-TRV68 Flashing No Tape and Eject Symbol
If it were worth repairing, as a Sony agent, I would replace all of the capacitors and clean up the board then reset the mechanism and test. Probably too old being 2001 vintage.
11/19/2023 12:20:58 AM • Sony Handycam... • Answered on Nov 19, 2023
SONY mini HandyCam model V569. HOW DO YOU TURN ON A SONY V569?
Question edited to add full model designation. Question moved from Sony Computers. This doesn't seem to be a very well known model. It is not even listed on their website. https://www.sony.ca/en/electronics/support/cameras-camcorders/manuals/results?query=V569# There are normally two batteries, a small one that just saves memory and runs the operating system, and a larger battery that actually powers the camera. Try contacting Sony direct There is a bit of help here, but not enough. https://www.google.com/search?q=SONY+V569 ..
8/4/2023 4:37:50 AM • Sony Handycam... • Answered on Aug 04, 2023
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
4/13/2022 7:57:16 AM • Sony Handycam... • Answered on Apr 13, 2022
Handycam CCD-TRV70 Hi8 camcorder. Why is it suddenly playing all tapes fuzzy, with no audio?
The record / playback heads probably need cleaning, using a compatible cleaning tape. Failing that, it is either damaged or broken.
1/5/2021 11:43:05 PM • Sony Handycam... • Answered on Jan 05, 2021
2answers
Blue screen on TRV260 playback
TRV260 nail-polish head attack: eek. Acetone is a powerful solvent capable of dissolving plastic parts, plastic gears, housing and insulation. Besides that, it leaves a residue of microscopic crystals which have probably contaminated the highly-polished metal head drum. Not to mention gumming up the bushes and bearings. With your next camera, rather use a head-cleaner DV-tape.
12/20/2017 4:11:58 PM • Sony Handycam... • Answered on Dec 20, 2017
Sony dcr-hc62 won't record
Memory stick could be fubar. I have a bad sd card that I can record to and will work. Then a few days later the data is corrupted, and I have to reinstall it / same pattern. Try another stick to verify that it is the stick and not the camera electronics.
9/20/2017 10:43:11 AM • Sony Handycam... • Answered on Sep 20, 2017
Sony Handycam HDR-CX12 Flash Media Camcorder Logo
11 questions posted
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
camcorder not record video format
  • Video Cameras
