This camcorder does not record video, because the camcorder will not format a memory card or create the image database file to allow film to be taken and recorded. Camcorder will take photos, power on, etc.
Do you get any kind of error code?what type of memory stick are you using?how big is the ms capacity?may need to try using a diff ms or try using ms with diff devices.if diff ms works fine.may need to format ms using computer first (using card reader if available) and camcorder last.may need to reset camcorder (make sure cam is on when you press the reset button.hope this works.thanks :)
This
message appears if data on the hard disk / internal memory / memory card of the
camcorder is handled directly with the computer. When you handle data of the
camcorder, use the supplied software, PMB.
If you
directly handle files or folders of the camcorder from the computer, image
files may be damaged or not be played back. Return the files or folders to the
condition before handling, or format the recording media with the camcorder.
* If you
format the recording media, all movies and still images including protected
ones will be deleted.
* Sony
will not accept responsibility for any results caused by handling data on the
recording media from the computer.
This is the same to the images in the camera, if you have to do something with the images in your camera by PC, you won't playback it too.
