Question about Sony Handycam Video Cameras
Handycam CCD-TRV70 Hi8 camcorder. Why is it suddenly playing all tapes fuzzy, with no audio?
Posted by Pete Sewell on
Tony Parsons
  • Sony Master
  • 6,347 Answers
The record / playback heads probably need cleaning, using a compatible cleaning tape. Failing that, it is either damaged or broken.
Posted on Jan 05, 2021
5 Related Answers
Anonymous
  • 4402 Answers
SOURCE: Sony Handycam Vision ccd-trv308
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Jan 22, 2008
Anonymous
  • 10594 Answers
SOURCE: this Sony Handycam Hi8
Sorry? whats not being shut? Please give details about problem you facing.
Posted on Jun 01, 2008
sardanadixit
Dixit Sardana
  • 813 Answers
SOURCE: manual for camcorder/sony-hi8 camcorder-ccd-trv68
Download the manual from:
http://www.henrys.com/manuals/sony/CCD-TRV58(En).pdf
Please rate this solution as it helps us in helping you and others like you.
Posted on Sep 08, 2009
omtronixom
om sharma
  • 172 Answers
SOURCE: sony ccd trv43 doesn't play hi8 after placing an old video 8 tape
Try to clean video head with cleaning cassette, if same position than video head need to be change
Posted on Mar 29, 2010
bhargav
  • 66 Answers
SOURCE: HELP, I have borrowed an older camcorder from a
Tape can not be inserted backward in.It is impossible to to insert cassette inside video wrong way.
If it is not ejecting its eject switch might have got broken by physically pulling its cassette compartment outward before closing last time.
Its mini switch is very fragile in all sony models. so only way is to take to technician to bring it out.If i were you,I would buy used one from ebay at lower price than repairing.
Posted on May 07, 2010
1helpful
Play back pre recorded HI8 tapes on my TRV130?
The Sony DCR-TRV130 is a D8 digital camcorder which is not compatible with Hi8 camcorders.
You need to have an Hi8 camcorder or DCR-TRV103 or similar camcorders that backward compatible with Hi8 camcorders.
Everytime I press play during playback it will play for a little while the starts beeping and stops
The unit likely has a problem in the transport mechanism which moves the tape. Maybe time to retire this unit?
I have a working TRV81 Hi8 HandyCam and 15 Hi8 tapes I'd like to convert to digital and make ready for edit on IMovie (Mac). Would appreciate any advice....
The only way to do that is to play it in a device that plays Hi8 tapes and somehow converts it to a digital signal (likely through firewire as DV), then capture it to your computer just like a digital camcorder.
There are several ways:
1. Buy a device (like a camera) that plays it, output through RCA cables to your other camera or tape deck that is digital through the line in, and then just record that. (Alternatively, you could put that signal into a DVD-R machine and record onto a DVD, then just copy the files off the DVD, if you don't have a way to capture DV through firewire.)
2. Buy a device that plays Digital8 (same tapes, but miniDV FORMAT) and output directly from the tape through firewire. This means you must buy a SONY (only brand that made [now discontinued] Digital8) camcorder or deck [if decks were made, though those are usually expensive].
So, the simple answer: get a Digital8 camera and capture, or get another digital camcorder and a Hi8 camcorder and play through the digital one into the computer.
Buying a Sony Handycam (OLDER model) will be your easiest option, and probably possible on ebay, etc., for $100-$200.
Short of this, you could look to a friend or a professional solution for just getting the tape copied (like VHS->DVD services exist, there is probably some place you can mail your tape to).
EDIT: I should add: You included "8mm" in your title-- that is a bit confusing. 8mm refers to a few formats. One is film (obviously not what you're referring to), but then there is the older "8mm" tape format; it's like Hi8, but I believe it's actually not the same tape-- unlike Digital8 and Hi8which share a physical medium. I don't think you can get an 8mm -> Digital device, so you'd need to go through the RCA cables, as described above. [And though Hi8 is actually 8mm in width, it's not quite the same as the other "8mm" format... for whatever odd reason someone decided.... frown.gif]
However, I suspect you ARE actually working with Hi8, so this shouldn't be a problem.
1helpful
Can tapes from a Digital 8 camcorder play on a Hi8 xr ccdtrv87?
No, CCD-TRV87 is analog camcorder that can not playback digital format video-8 tapes.
Sony ccd trv43 doesn't play hi8 after placing an old video 8 tape
3helpful
Problems with playing cassettes recorded on a hi8 camera
DCR TRV140E is a Digital8 camera
CCD TRV87E is a Hi8 camera,
(Hi8 is an analog format)
the tapes are the same size, wont help, the recording systems are not compatible
send them to a lab service ?maybe if there are only a few
or ebay a Hi8 camera and transcode them yourself
its not a solution, at least it clarifies the problem
Hi8 Playback Problem
Clean the tape heads and see if that makes a difference.  If that doesn't work, it could be the tape motor is going out.  Thats typical behavior when that happens.
2answers
HELP
the heads could be dirty or the tape path could be out of alignment.
1helpful
2answers
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Video Cameras Logo
Top Sony Video Cameras Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
