20 Most Recent
AMD K7 , 800Mhz (amdk7800mpr24b) Questions & Answers
Play dvd movies
Its not your CPU speed that burns or Views DVD its the actual player in your computer. You may have a CD player in your computer but can it actually read DVD? can it burn DVD???. If it can then you will need the software to play it back Windows media player wont play back DVD unless you have download the updated codex for it. One of the best software players is InterVideo Win DVD.
Is my main board defective??
Hi, The problem sounds to me like you need to access the bios and make sure the AGP is enabled. If this is enabled then you may need to go to the manufacturers site and download the drivers for your board and operating system. With a P3 you should have no trouble running XP so if you are not using this already then perhaps you need to upgrade as XP has a very good set of drivers built in and will run most video cards and sound cards
Regards mistyman
Prossesors
It will depend on what model of gigabyte motherboard you have? Do you have the exact model number?
cpu-z or everest will tell you if ur unsure.
Where do I start computer upgrade
Your machine is very short of power required for win 10, I would like to see at least 8 GB ram, and a faster processor, yours is at the bottom of tests. Perhaps you should look at a new machine with win 10 installed. You cannot upgrade xp to win 10. You will have to purchase a win 10 license, you missed the free upgrade period.
On my Back-ups ES 550 the "Building Wiring Fault"
This red light usually indicated the ground on the outlet the UPS is connected to is not properly connected to ground.
It could also mean the ground and neutral wires on the connected outlet are reversed.
