Computers & Internet Logo
Amanda Cartner Posted on Jul 06, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a very old amd computer. I am trying to connect a monitor to the tower. once connected I get a no signal message.
This tower is at least 10 years old, but has pictures and videos on it I am trying to retrieve. Is it possible the connection cord needs to attach to the pink port on the back of the tower instead of the blue port that most newer computers use?
Mark Cheong
Level 3:
Master:
  • AMD Master 791 Answers
  • Posted on Jul 06, 2018
Mark Cheong
AMD Master
Level 3:
Master:
Answers
791
Questions
0
Helped
476224
Points
2475
First I'm not a AMD computer tech.
* normally I would suggest you check your warranty and call for service. Though I'm afraid most of us have retired or the computer companies have gone away (I remember Pan Am and Radio Shack)
* I'm amazed you still have a running AMD core. Mine have all failed decades ago. I really miss the VersiCAD and my Studio 9 Video editor. It's hard to let go knowing you've already spent $100's or more on equipment and software.
* Getting back to your monitor situation. You will need a converter to accept the old cable. A better bet would be to check your local thrift shop or swap meet for old tube style monitors (Pre Y2K). I used to get one for less than $5.
* Most of my computer problems stem from system crashing and newer replacements not working with the older software and formats. IE; I still have MP3 burner programs that will take a Audio CD and digitize the music. None of the computers can do this anymore (result of NAPSTER and copy rights).
* Recovering data is a bit easier as you can use an external drive (ATA format) and just connect it up via USB to a laptop or other desk top to transfer files to another upgraded drive like a SATA drive or even a USB flash drive.
* You may be able to recover programs but in most cases it won't work on newer computers unless your running a dual OS system (Run windows, DOS, Mac, on same computer but at different times using various start up methods)
* Most old software does not take advantage of upgrades as they didn't know about the upgrade at the time of development. Only a few programs have survived Y2K. Remember Wang, Lotus 123, DOS?
* Suggest you transfer your data as soon as possible to archive disk. Keep the old hard disk around for additional back up copy if you loose or damage existing data.
Aloha, ukeboy57
PS: Oh, to answer your specific question about no signal. Once you get the right monitor and still no signal then you need a new (or salvaged) Monitor card. It is possible that you may come across a Monitor card for your newer TV set but I don't remember if there were HDMI or other Hi Deff TV's around in the 1990's.
Just keep an eye out at old community collection stores for older computer equip.
NOEL
Level 3:
Top Expert:
  • AMD Master 8,606 Answers
NOEL
AMD Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2322215
Points
68630
5 Related Answers
Anonymous
  • 6966 Answers
  • Posted on Feb 15, 2008
SOURCE: hooking up computer to philips 60pp935217 AV5 HDTV connector?
Hi Roger,
Initially, pls try lowering the screen resolution of your PC. This can be done at the Display Properties/Settings tab and then move the slider of the Screen resolution towards the left, Apply OK. In some instances, you need to also lower down the Screen refresh rates in the Monitor tab of the Advanced Properties.
If your concern has not been corrected after completion of the above procedures, then other methods can be considered.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Anonymous
  • Posted on Mar 17, 2008
SOURCE: can not connect
Power up headset. Press and hold the + and - Volume buttons until the red and blue lights flash . Your phone should now pair with the headset. For passcode I used 1234 and this worked.
Regards
Moss
Anonymous
  • 10 Answers
  • Posted on Mar 06, 2009
SOURCE: Sony VGP-WKB5 VAIO Wireless Keyboard unable to connect
just found?
Anonymous
  • 3600 Answers
  • Posted on Aug 24, 2009
SOURCE: Need a cord to connect OLD computer to NEW printer
You can take the cord to Radio Shack and get a 24 pin serial dongle to 9 pin dongle. take a picture of the back of the computer and of the cable if you have and they can find an adapter for you. Thanks for using fix-ya and rate this if it was helpful.
avid101
joneeboy
  • 66 Answers
  • Posted on Jun 18, 2010
SOURCE: Dell monitor S199WFP....the blue power light stays
What do you mean your screen goes black. It is black to start isn't it? Does it come on at all?
If you meam you are getting a display, but it goes off, you need to check the power settings for your monitor, that are set by your PC. Click start, then control panel, then double click display. Then in the Dispay Properties window, click the Screensaver tab at the top middle.In the lower half of the page which opens, you can find power settings, and the rest is self explanatory. If this is not the answer to your problem, you need to give more detailed information.
One check you can do is to disconnect the signal cable from your monitor, and switch power on, and see what is displayed. You may well need a new monitor, but before running off to buy one, try to borrow one to connect to your pc, and also if possible, try to connect your monitor to another pc, or to a notebook/laptop.
Problem with the monitor
hi,
first of all,try to connect the cable to other device(laptop) to see if is working,because if you receive the message"No signal" then the monitor is working but the cable/signal did not cross to the monitor,then is working with other device then try again or check if you can connect the monitor with different port if you monitor has one vga/dvi or hdmi.
I have emachines w3653 and the no signal keeps popping up
Are you still using the monitor that came with or have you replaced that monitor? The monitor or the cable connecting it to the tower could be faulty. If possible try connecting another cable between the monitor and the tower and then if you still get the no signal message, try another monitor altogether.
When monitor is turned on, the words 'Check signal cable' appear. What does this mean? Thank You
Hey!
If you get that message on your screen. It is possible that there is no communication from the tower to the monitor.
Please make sure that the cable that is connected from the monitor to back of the tower is properly connected.
Also check if the lights on the tower are on and try to check if they're the ones that you normally see when you use your computer. It could also be possible that the computer is encountering a problem.
Hope this helps! :D
It says no input signal
Try a different monitor, to see if the video-card on the computer is the problem.
2answers
Monitor not connecting to tower. it is plug in to the tower. but shows that it is not connected.
three things can be the issue here:
1. No signal from the tower (VIDEO CARD)
2. Bad cable or bent pin on the d-sub 9-15 pin vga connector.
3. Bad signal board inside the monitor itself.
Things to try:
1. another computer.
2. check the signal cable for bent pins.
3. check the video card in the tower.
Before you "think its a bad monitor" you always want to assume the computer first as computers are 9 times out of 10 why the monitor is not coming on such as BIOS errors, Bad video card, bad power supply etc etc.
PLEASE BE CONSIDERATE! When rating and leaving positive feedback for your free answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Wont start up
Check physical connections first, check monitor cable if securely plugged in and then check power light of monitor. If power light on monitor is amber or yellow it means that monitor is not getting a signal from cpu/ tower. Try to do a power drain on the computer, remove power cable at the back of the computer and then press and hold the power button for 10 secs, after that plug in power cable again and restart the computer.Check if there is any connection if not then try to use another monitor, a known good one. If you get a video from another monitor it means monitor is already defective.
Monitor just goes blank suddenly - goes white, black, blue, green even been brown- can happen any time - today about 4 times yesterday just once. Only thing I can do is hold on/off switch till computer...
Take a look at the back of the monitor there must be a cable which is connected at the back of your computer tower.
If you take a look at the back of your computer tower you will see that cable has a big plug with two screws on the top of it. It could be blue in color or may be grey. ( The name of that cable is Video cable )
Now what you have to do is to take that cable out of the computer. Now switch on the computer.
If you see a message on the screen saying " NO INPUT SIGNAL " :- That means your monitor is fine. If it does not shows that. Then your monitor is bad.
Remember the power cable of the monitor should be connected while doing the above steps.
Now incase you can see the "NO INPUT SIGNAL " message on the screen. Even then the problem persist.
It might be possible that the Video cable has gone bad. You need to consult a hardware technician for your monitor.
Try this and let me know if it helps.
It is turned on but screen stays black once tower is powered up.
we need to make sure whether its a Tower problem or monitor Problem>
Do this simple test> Disconnect the Cable that connects the Tower to the Monitor(while the tower and the monitor are on)> then see if you have any error msg on the monitor screen> if you have someting that says "Chk video cable" or " no signal"
Ur monitor is fine and the tower is faulty> IF not thn ur monitor has gone bad>
2answers
I have a HP s3020n slimline the pc is running but not sending any signal to the monitor
Well... try un-plugging the VGA cable... ie., the monitor cable behind the tower...... if u get a message on screen saying No VGA Input... can confirm there is no issues with the monitor...
if you are using graphic card in computer unplug that and connect the VGA cable to normal display card came along with the computer and try...
or if you have another monitor... u can try connecting that to the tower which is not sending the signal to monitor and try....
even then you get the same problem... get an new graphic card... (if you dont have other monitor try with new graphic card)
Speakers killed my moniter
Well as you have already tried disconnecting the peripherals from your computer, and tried restarting the computer too which did not help you, it sounds to be an hardware issue with the monitor. However if incase you have not tried this, you can disconnect the monitor completely from the tower, power on the monitor, if it powers on and you get a message as no signal, your monitor is working good. If not replace the monitor. If the message appears on the monitor screen, disconnect everything from the tower, push and hold the power button on the tower for a minute. Connect just the monitor and check for any display. If you do get display, thats good, connect one device at a time and check to see if the display appears.
If theres no display with just the monitor connected, the issue would be with the graphics card. You may need to replace it or get the system repaired.
Top AMD Computers & Internet Experts
ExpressFiX
ExpressFiX
NOEL
NOEL
john h
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
