Computers & Internet Logo
Question about AMD Computers & Internet
Hi there, just having a lot of difficulty with accessing my messenger account. It automatically logs me out before signing in amd comes up with an error- fatalerror domain code: 401 HTTP Error.
Posted by Rebekah Louise Daly on
5 Related Answers
Anonymous
SOURCE: Unable to open yahoo email : error message code 2
Hi Tech support,
I am unable to open yahoo mail from last couple of days. It gives an error message after logging in and no emails open.
pls help me
Posted on Oct 24, 2008
Anonymous
  • 30 Answers
SOURCE: keep getting a 401 unauthorized code when trying to log in to sur
Your Web server thinks that the HTTP data stream sent by the client (e.g. your Web browser or our CheckUpDown robot) was correct, but access to the URL resource requires user authentication which 1) has not yet been provided or 2) which has been provided but failed authorization tests. This is commonly known as "HTTP Basic Authentication". The actual authentication request expected from the client is defined in the HTTP protocol as the WWW-Authenticate header field.
Generally this error message means you need to log on (enter a valid user ID and password) somewhere first. If you have just entered these and then immediately see a 401 error, it means that one or both of your user ID and password were invalid for whatever reason (entered incorrectly, user ID suspended etc.).
401 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle:
Obtain an IP address from the IP name of your site (your site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
Open an IP socket connection to that IP address.
Write an HTTP data stream through that socket.
Receive an HTTP data stream back from your Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code it recognises as '401'.
Fixing 401 errors - general
Each Web Server manages user authentication in its own way. A security officer (e.g. a Web Master) at the site typically decides which users are allowed to access the URL. This person then uses Web server software to set up those users and their passwords. So if you need to access the URL (or you forgot your user ID or password), only the security officer at that site can help you. Refer any security issues direct to them.
If you think that the URL Web page *should* be accessible to all and sundry on the Internet, then a 401 message indicates a deeper problem. The first thing you can do is check your URL via a Web browser. This browser should be running on a computer to which you have never previously identified yourself in any way, and you should avoid authentication (passwords etc.) that you have used previously. Ideally all this should be done over a completely different Internet connection to any you have used before (e.g. a different ISP dial-up connection). In short, you are trying to get the same behaviour a total stranger would get if they surfed the Internet to your Web page.
If this type of browser check indicates no authority problems, then it is possible that your Web server (or surrounding systems) have been configured to disallow certain patterns of HTTP traffic. In other words, HTTP communication from a well-known Web browser is allowed, but automated communication from other systems is rejected with an 401 error code. This is unusual, but may indicate a very defensive security policy around your Web server.
Fixing 401 errors - CheckUpDown
When you set up your CheckUpDown account, you may optionally provide two items 2. Web Site User ID and 3. Web Site Password. You should provide these only if your site uses HTTP Basic Authentication. If you provide them, the CheckUpDown robot always uses them. This will result in a 401 error if in fact your site does not use this authentication. Conversely, if you do not provide them and your site does use this authentication, you also get a 401 error.
If however your URL is open to all comers, then an 401 message should not appear. Because it indicates a fundamental authority problem, we can only resolve this by negotiation with the personnel responsible for security on and around your Web site. These discussions unfortunately may take some time, but can often be amicably resolved.
Alternatively or the other way around is :
open the XP hosts file, and do a manual insert there.
The hosts file is located at: C:\WINDOWS\system32\drivers\etc
The entry is: 192.168.0.1 www.routerlogin.net
You might need to flush your DNS records at this point, or simply restart your computer.
And then use the following URL to access the admin page:
http://www.routerlogin.net/setup.cgi?next_file=start.htm
***Here is another solution to the problem, which is a fairly straight-forward way to disable the annoying wizard.
Type in your browser:
http://www.routerlogin.com/CA_HiddenPage.htm
Select: Disable Configuration Assistant, and click on Apply.
You can re-enable it by navigating to http://192.168.0.1/CA_HiddenPage.htm (where 192.168.0.1 is your router’s IP address)
Posted on Apr 11, 2009
Anonymous
  • 265 Answers
SOURCE: error code 8e5e03fe
uninstall msn messenger to begin with and download and install once again.
If this still happens reset your router, the router may of changed itself to strict so just reset :)
Posted on May 24, 2009
Anonymous
  • 33 Answers
SOURCE: 8e5e03fe
well i have esentials right, go to your C:\Program Files\Windows Live\Installer ok in that folder you will have possibly 3 folders one should be called wlarp one called wloobe and another wlsres.dll (no need to worry bout the .dll) with one of the other applications click it and it should come up in one of them re-install or repair...click repair or re-install
Hope it helps
Posted on Mar 03, 2010
Anonymous
SOURCE: HI how can I fix
goto start, my computer, c drive , delete the windows folder. If it gives message that it can't be deleted ,then take the battery of the laptop and fix a TNT in that place and throw the laptop
Posted on Nov 29, 2010
Have two accounts with gmail and I have difficulties in logging in to thobeka.thamage @gmail.com and when I try to log in it goes automatically to [email protected] the second account
Try signing into the second account, then signing out of the 2nd account. Then sign into the first account.
Other sources for the issues could be stored password. Does this happen on other computers and other browser types? Clearing you stored password would help.
Have you ever linked the accounts together or do the accounts have the same password?
3helpful
Hi i just created my yahoo mail account hoping that this account will help me to have my yahoo messenger but when i started to sign-in at yahoo messenger it denies my log-in info..how can i use my yahoo...
To login to your yahoo messanger, carefulluy login your yahoo user name and password to your yahoo messanger.
also if is not working go to mail.yahoo.com and login to confarm your account is still valid.
try it and get back to me.
1helpful
2answers
I have been diconnected from the chat, because i signed in to yahoo messenger. how do i disconnect from the yahoo messenger
You disconect fromchat because you signed in the yahoo messenger
Messenger is a different applicatio from chat. yahoo considers the user of the application as different, so yahoo disconects you from one application from the other
7helpful
2answers
How to register at yahoo messenger?
When you a have an account with yahoo mail automatically you are sign to yahoo messenger. So you need a yahoo ID before you can enter yahoo messenger and you have you have yahoo id you will log in with your yahoo id and password. to enter yahoo messenger.
You can click on yahoo messenger icon and enter you id and password and then click sign in.
But if don't have the yahoo messenger icon, just go to yahoo and click on yahoo messenger and enter your id and password to sign in.
2helpful
2answers
Cant remember the 2 questions like where did u go on ur honeymoon
You will have to take the same route as if someone has accessed your account and changed the security questions
Follow the route for 'my account has been compromised'
https://edit.yahoo.com/forgotroot/
Someone is signing into Yahoo messenger with my account info?
It must be because your yahoo messenger on your PC at home is configured to ' Sign in automatically'.... So the moment someone powers on your PC at home and logs in ( or it reboots due to power cut etc ) , you get disconnected in your yahoo messenger at your office system.
Sometimes when am online on messenger i got sign out,and it says i log in on a different computer,what should i do to protect me account?
when u are connected through your messenger and you open your inbox, with the kind of features yahoo has now, it will automatically sign you-in, in your inbox, (but since you can only chart one at a time with your id), and automatically log you off from your messenger. if you try to sign in back, it will then log you from your inbox chart. it is now left for you to choose the one you wish to chart with.
When i use my yahoo default mail to reply my yahoo messenger signs out and says i using another computer or device
This is because someone else or some other thing is logging into your account elsewhere thus logging you out. Could you have an iPhone, phone, another computer (i.e. Laptop) with your account saved. i.e. if you startup your laptop or someone else does at your house/office and it automatically logs your pre-saved Yahoo account in while your already logged in, it will log you out and return to you that message.
1helpful
2answers
My yahoo account has been locked
try signing in on the yahoo log in page after successfully signing in to your account try messenger again
1helpful
2answers
Unable to Login to Yahoo Mail.
Hi yahoo
i am unable to log in my yahoo account..if i typed my user name and password ..again it comes same log in page ..
and i am able to access my email in my blackberry device ..only my desktop i am not able to log in ...
pls help me some one for this problem it will grate for me
Nov 30, 2008 • Yahoo Mail
Top AMD Computers & Internet Experts
Steve
David Shaub
shadow
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
