20 Most Recent
Sony Handycam HDR-HC7E DV Digital Camcorder Questions & Answers
Loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Hi I've connected a firewire cable between the
No need to change any settings it will auto connected.Check your cable may be its faulty.
Try other think to attached your iMC.If still not working then You Firwire driver not instal.
Blown Sony HDR-HC7E fuse or board?
There are internal fuses yes, but they are surface mounted ones and not a DIY repair. There are protection diodes internally as well. If the adapter was not the correct one, it is possible that it popped the diodes and fuse.
You can buy the service manual from Sony directly for a cost.
Hope this helps,
Dan
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
Blue screen on TRV260 playback
TRV260 nail-polish head attack:
eek.
Acetone is a powerful solvent capable of dissolving plastic parts, plastic gears, housing and insulation.
Besides that, it leaves a residue of microscopic crystals which have probably contaminated the highly-polished metal head drum.
Not to mention gumming up the bushes and bearings.
With your next camera, rather use a head-cleaner DV-tape.
