20 Most Recent Rio Nitrus MP3 Player Questions & Answers
0answers
0answers
I need driver for Rio
Well, you can find and downloaded it here: www.nodevice.com/driver/category/MP3_Player.html
Regards
2/10/2011 11:43:26 PM • Rio Nitrus MP3... • Answered on Feb 10, 2011
What driver do I need for Rio Nitrus MP3 player to
Hi, kindly get it downloaded here: www.nodevice.com/driver/category/MP3_Player.html
Regards
2/10/2011 11:30:59 PM • Rio Nitrus MP3... • Answered on Feb 10, 2011
0answers
3answers
"RESTARTING"
I encountered the same issue with my Nitrus. After following instructions to upgrade firmware, I had the "restarting" message on screen. I then took the unit apart once again. I could hear the drive making a noise. I tapped on the back of the drive with a screwdriver and the player started working properly.
4/7/2010 1:36:45 AM • Rio Nitrus MP3... • Answered on Apr 07, 2010
Same problem here. My Nitrus plays the music on
check that you have sellected the use on the rio aswell
11/1/2009 5:31:17 PM • Rio Nitrus MP3... • Answered on Nov 01, 2009
3answers
Music won't upload onto my Rio.
I have not been on FixYa for about a 1/2 a year so as I seem to be the only person answering Rio problems I have only just seen your problem... Sorry, so if you haven't bought an iPod yet (or you want to try and fix this anyway) then I would recommend wiping and rebooting your player:
Windows only.... Please post if you are not using windows...
Open My Computer with your Rio plugged in.
Right click on your Rio player and click on format.
Leave the default values - if it asks you something then use your initiative.
Then click on format.
Then when it has finished formatting go to your firmware (can be downloaded from: http://www.digitalnetworksna.com/support/rio/product.asp?prodID=112).
Follow the instructions and then it should load the firmware onto your player.
When it has done then your player should (in theory!) work properly.
Hope this helps
Mowcius
11/1/2009 5:21:48 PM • Rio Nitrus MP3... • Answered on Nov 01, 2009
Rio nitrus
If you look in the hints and tips section for the Rio carbon there are many things I have posted that should help you. I have no hands on knowledge of the hardware of a Nitrus but I understand that it is similar to the carbon.
Hope this helps,
Mowcius
10/14/2008 2:30:23 PM • Rio Nitrus MP3... • Answered on Oct 14, 2008
Error message "failed to connect to player" "data blocked failed"
Don't buy an iPod...
I would recommend wiping and rebooting your player cos it's cheaper:
Hope this helps
Mowcius
6/7/2008 10:12:49 PM • Rio Nitrus MP3... • Answered on Jun 07, 2008
RIO Nitrus
It says "upgrader" because it is looking for a firmware upgrade - you will not be able to get rid of this message without doing the firmware upgrade - go to the rio website and follow the instructions for doing a fimrware upgrade - the msg will be removed, and you will be good to go
-Tha Mp3 Doctor
5/28/2008 8:34:46 PM • Rio Nitrus MP3... • Answered on May 28, 2008
"Failed to connect to player, Operation timed out"
Hope this helps
Mowcius
5/14/2008 8:41:09 PM • Rio Nitrus MP3... • Answered on May 14, 2008
Ok Rio nitrus is great litle thing, and I had the same problem. This is what you should do:
1) download latest firmware for rio nitrus http://www.rioaudio.com/support/rio/downloads/Nitrus/RioNitrus_firmware_123.exe
2) unpack firmware
3) connect Rio Nitrus to your comp;
4)While holding menu buton press power button, you sholud see on display showing UPGRADER text;
5) Then upgrade the firmware ( note that this will erase all the songs- read the read me file that come with firmware);
Although I allready have the same version of firmware v.123 like the one that upgreded this solved the problemm.
4/17/2008 9:08:51 AM • Rio Nitrus MP3... • Answered on Apr 17, 2008
Transfer error - Disagreement between player and software
I had the same issue and I eventually re-formatted the player. Once I had finished that, it seemed to work again, letting me add songs.
8/31/2007 11:43:44 PM • Rio Nitrus MP3... • Answered on Aug 31, 2007
My rio nitrus will not show anything on the screen
Ok. You have reset your device, there is a reset hole next to the DC-in hole. Then if it still not working then you have to ask for a new lcd screen/ lcd screen module. That means the LCD of your MP3 Player isn't working anymore. Good Luck
6/25/2007 11:46:07 AM • Rio Nitrus MP3... • Answered on Jun 25, 2007
Saving Settings
1) Make sure that you use your MP3 Player carefully. Don't drop it. and put it in a safe place. 2) Charge your Player only when its battery nearly empty. 3) leave some storage available, like 10% of your storage. 4) Unplug it from your PC when you aren't using it. 5) Use safe removal when removing it from your PC. 6) When you don't use it, Shut it down. Good Luck
6/9/2007 3:57:53 AM • Rio Nitrus MP3... • Answered on Jun 09, 2007
Rio nitrus will not power up
I took ny Rio Nitrus apart trying to fix the screen & noticed that the rechargable battery connects to the motherboard with two flimsy little wires and a pinhead worth of solder. If you've tried everything else, it'd be worth your time to take off the back and have a look 'cuz a drop could easily have shaken one of these wires loose.
5/7/2007 5:00:44 AM • Rio Nitrus MP3... • Answered on May 07, 2007
Singing cuts off
Is this occurs on every file? Rip or Re-encode the songs you wish to use and then transfer them back to the Rio. The purpose of re-encoding is to ensure that there are no bad frames in the completed song file. also try to Rip or Encode your audio at a higher bit rate. if it is try to update to the latest firmware for the Rio. This can be found at http://www.rioaudio.com/support. If you are currently using the latest firmware, flash the Rio again. I hope it will help you.
12/7/2005 11:08:41 AM • Rio Nitrus MP3... • Answered on Dec 07, 2005
Rio Nitrus MP3 Player Logo
30 questions posted
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
ADMIN Andrew
ADMIN Andrew
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Rio Audio Players & Recorders
Most Popular Question
driver need rio nitrus mp3 player
  • Audio Players & Recorders
