20 Most Recent
iRiver iFP-195T 512 MB MP3 Player Questions & Answers
Lost my installation cd..
Go to this page and download required drivers.
http://www.iriver.com/html/support/download/sudw_list.asp?searchProductIdx=38&searchCategoryIdx=1&searchString=&page=1&idx=&tmpSearchProductIdx=38&tmpSearchCategoryIdx=1&tmpSearchString=
Please rate this solution
My iRiver e200 does hang...and it displays "USB busy.. Do not Disconnect if I connect it to PC. And I cannot play my MP3s
Hi there! Well it sounds like the flash memory in your device has failed. This may not be the case. There is no way to say without testing and diagnostics, however if you can not access the files saved to the memory via the device(Playing the files) and the computer can not access that memory when connected, there is a strong possibility that your memory has failed. I am not sure the age of the device but it is well documented that all flash memory will at some point fail because it can only be read and re/written X amount of times(this is normal). Typically most devices will reach "EOL"(End Of Life), or end of use before the memory fails. The likely hood of recovering the files located within the inaccessible memory is very unlikely but may be possible. Replacing the memory chip in the device is possible but not feasible. I hope I have been able to help you today. Please if I misunderstood your question let me know so I can get you the appropriate help. Thank's Mr.Mike
