SOURCE: Iriver won't let me upload from CDs and transfer....
go to my computer and open the C drive /create a new folder my music (rename it) ...ok now plug up iriver to pc...again go to start/my computer/ see the iriver drive open it...now you should see all the files on the iriver also...place both window side by side (or top & bottom) and click & drag (or copy & paste) from both iriver and pc...now you can save and copy from either one..........
Testimonial: "Brilliant, thanks. I was trying to copy them from the iRiver app, instead of the iRiver folder."
SOURCE: I cannot upload picture onto my pc
Does the PC pop up with anything when the camera is plugged in? if so, make sure the camera is in plyback mode and check windows explorer, under My computer, there should be a extra drive letter pop up.
If not then the USB socket can become damaged easily (have a look). If the socket is damaged, then you can either get it repaired or buy a SD card reader. that stays connected to the PC through it's own USB cable, you take the SD card out of the camera and plug it in to the reader (this is a better and cheaper option)
Cheers.
SOURCE: My iRiver T30 has always had difficulty
There may be a driver issue as I've personally had problems with my iRiver IFP mp3 player and would try to load the driver every time I connected the player to my Windows based computer.
Assuming you have a Windows based operating system, I would completely uninstall the iRiver Music Manager in add/remove programs in the control panel, restart the computer and try reinstalling the program again.
SOURCE: my iriver t7 starts on the same song when powered
try and erase all the songs and sync it again
