20 Most Recent iRiver X20 MP3 Player Questions & Answers
3answers
Downloading movie length DVD to iriver x20
Yes, you need to convert all your movies to a format iRiver and understand and play.
Here's a link:
Movie Converter for iRiver and instructions
I'm not sure whether Movie Converter supports original DVD files. If that is not the case, then you'll have to convert DVD video into a format that iRiver X20 can use, and then feed that new video to Movie Converter.
However, that would be a bit redundant: to save on time and quality, you could use other video Conversion tools, such as SUPER:
http://www.erightsoft.com/SUPER.html
After loading your DVD, you set the parameters to mirror those accepted by your iRiver model. In case of iRiver X20, those parameters are:
Extension: AVI [[also known as container]]
Video Codec: WMV9 SP, MPEG-4 SP [[MPEG-4 = XVID, DIVX]]
Video Resolution: max 320 × 240
Video Framerate: max 30 fps
Video Bit Rate: max 512 kbps
After successful conversion, upload your new video file to your iRiver X20 and play it back. If it plays [and plays correctly] - then congratulations - it works! If it does not play, then you might have made a mistake while setting the output parameters in SUPER.
Hope it helps. Rate me. Thanks.
.:: Cyberneticus ::.
6/26/2021 9:15:49 AM • iRiver X20 MP3... • Answered on Jun 26, 2021
0answers
I river mp3
Be the first to answer 9/27/2017 9:18:04 PM • iRiver X20 MP3... • Posted on Sep 27, 2017Be the first to answer
3answers
Can I 'hide' audio files anywhere?
unfortunately no matter where you put the file it will appear in your music library!
the only way to hide it is to make the actual file hidden by modifying it!
1/3/2017 4:58:42 AM • iRiver X20 MP3... • Answered on Jan 03, 2017
White button is unstable
This is because the button has been used a lot or incorrectly, you will need to get it repaired.
7/10/2016 7:29:33 AM • iRiver X20 MP3... • Answered on Jul 10, 2016
Hard reset iriver x20 ?
Visit the following link http://www.iriverinc.com/lounge/loungeView.asp?selectPart=03&findWord=&sno=839&page=1&cateCode=03 Download the required manual and follow the instructions
5/13/2016 7:43:30 PM • iRiver X20 MP3... • Answered on May 13, 2016
0answers
How do I turn it off
Try holding down the "play/stop" button.. the arrow and square symbols. I hope that works! I have a different model so I'm hoping it will be the same.
3/3/2014 5:36:52 PM • iRiver X20 MP3... • Answered on Mar 03, 2014
0answers
0answers
0answers
2answers
Just bought an iriver S100
Go to settings, Advanced, Click Rebuild Database. Also make sure you are uploading songs through iRiver Plus 4
12/8/2012 10:21:39 PM • iRiver X20 MP3... • Answered on Dec 08, 2012
0answers
5answers
I've had 2 crashed iriver X20
Hi. I just had solved my Build Library problem. Use my solution on your own risk.
The solution is the following:
1. open up a player (find 8 screws, not 6, 2 of them are on the left side of the player under the round stickers)
2. jently take off a circut board. (you need to access its bottom)
3. Find a memory chip. It is labeled like "samsung k9hbg08u1m"
4. find chip's key meaning start of pin numbering (small circle on the corner). There are 48pins. 24 on the left side (1-24) and 20 on the right (48-25) see chip's manual http://catalog.gaw.ru/index.php?page=document&id=11348 page 4
5. On the right side find pins 32-29 (find them as the second 4 pins from the chip's circle key opposite corner)
6. Connect them together with some metalic wire (don't touch two middle pins on the right side of chip, it is chip's power supply).
7. Holding those pins together connect USB cable to player's socket.
8. After a while player will show error on its screen, get metallic wire out of pins, and then the player will be available as flash storage on the PC.
9. Format flash storage with quick format.
10. Disconnect and assemble the player back.
11. Connect to PC and upload new music.
12. Feedback to fzymarev()yandex.ru
12/3/2011 11:29:17 PM • iRiver X20 MP3... • Answered on Dec 03, 2011
How do i set iriver
You can shuffle music with Iriver S100.
It's quite tricky, took me for a while to figure out.
1. Go to music page and then play any music.
2. Prees and hold the right arrow > the sub menu will popup.
3. Go to 'Play Mode' and then volla !!!! choose whatever you want.
9/1/2011 12:24:10 AM • iRiver X20 MP3... • Answered on Sep 01, 2011
0answers
iRiver X20 MP3 Player Logo
121 questions posted
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
SmartAviator
SmartAviator
Mohammad Abumuailek
Mohammad Abumuailek
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • iRiver Audio Players & Recorders
Most Popular Question
decided upgrade firmware
  • Audio Players & Recorders
