20 Most Recent
Tascam 302 PRO DUAL CASSETTE DECK Single Dual Cassette Deck Questions & Answers
Service manual manuals
When I need to get a service manual I always order it from Stereomanuals.com . Rick delivers a perfect copy that is as good as the originals and I should know as I worked at Teac service in Arlington Heights IL on Golf Road.
Shows err 3 on power up.
It could be belts or internal cam motor contact sensors. The transports that Teac sells are not direct replacements and DO NOT WORK.
Shows err- 3 on power up.
I think it is refering to an external control device such as a wired remote. You might try unhooking external connections and then re-hooking them and then booting it back up. Good Luck
The CD tray on my Tascam CD-A500 CD/Cassette combo will not open.
I understand that your CD tray on your Tascam CD-A500 CD/Cassette combo will not open. Here are some possible reasons why this might be happening and what you can do to fix it:
- The CD tray may be stuck. If this is the case, you can try to gently pry it open with a flathead screwdriver. Be careful not to damage the tray or the unit.
- The CD tray motor may be broken. If this is the case, you will need to replace the motor. This is a relatively simple repair that can be done by most people.
- The CD tray sensor may be faulty. If this is the case, you will need to replace the sensor. This is a more difficult repair that should be done by a qualified technician.
If you have tried all of the above and the CD tray still will not open, you may need to contact Tascam customer support for further assistance.
Here are some additional tips to help prevent your CD tray from becoming stuck in the future:
- Do not force the CD tray to open or close.
- Be careful not to drop or damage the unit.
- Keep the unit clean and free of dust and dirt.
- If you are not going to use the unit for an extended period of time, unplug it from the power outlet.
I hope this helps!
Please I have a Tascam 2488neo hard disk recorder. It's bringing out the error message Code 04. SDRAM Initialize Error. What do I do now?
Just failed or bought it dead or ran 1day and died.(history matters)BY FAMOUS MAKER TEAC. mark 1 or MARK II modeL?TELL WHAT YOU ARE DOING ON THIS complex system just before the failure.Just simply turned on? or burning dvd-r or reading media. ? last page USA if is says contact TEAC AMERICA, INCa coin cell is inside my guess, and is long overdue if there.15 years old is near 2 times the life span of a coin cell battery.it has 80GB HDD that can very easily be badand a SDRAMand no SD cards, of any kind. ,USB port allows transfers to a PC>the manual only states thisbattery pack or batteries installed)
https://tascam.com/us/product/2488neo/downloadthe SDRAM does not plug in like PCsso is soldered down. make sure all batteries are good firstand if yes, make sure the PSU board is not bad with classic thenCAP Plague. error bad caps. . it is at least 2010 old. lots of reviews then and any batteries here are no good that old, and HDD can be bad, ask how to test in on a PC.so what is bad.1: batteries.2: CAP plague caps leaking bulged out. (wiki it)_!3: HDD bad. if not bad, best is to clone it now for later when it does die4: Sdram bad (only if power surged AC or lightning hits.5: PSU bad see #2
