Question about Tascam Audio Players & Recorders
Tascam 122 MKIII Problem/ no sound!
My Tascam had the usual issue of a worn out Gear C, got a new one in and every runs perfectly now. The issue is that it got no sound, nor there's any signal on the VU meters. Anyone with the same issue? And if it got fixed?
Posted by Hassan Shahid on
1helpful
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
1helpful
How do you hook up a Tascam 122 cassette deck to a receiver i tried to hook it up to my Nad 7155 receiver and no sound what am i doing wrong please help
cassette decks have line OUTPUTS. If it records there may be line inputs. Connect the OUTPUTS to the appropriate INPUTs on ur amp. Select the correct input on the amp. If it doesn't work u will need to verify the amp inputs work and that the tape outputs r active.
If so chg the cables.
1helpful
How do i hook up my tascam 122 cassette deck to my Nad 7155 reciever i tried
The RCA outputs sockets on the 122 connect to either tape 1 or tape 2 "PLAY". on the Nad.
The Line In Jacks on the 122 connect to the record of tape 1 or tape 2 rec of the Nad.
If you connect it to tape 1 connect both to that.
To listen to the deck you select either tape 1 or 2 depending which you have connected it too.
How do I get a stuck cassette tape out of the Tascam 202 MKiii
With this kind of mechanism you need to open the deck up and assist the cam wheel by hand to get the eject block and heads to go down to the stop mode. This is the only way to get a tape out without destruction to both tape and machine. I have done it a few times. If you can not do it yourself, I am in the Chicago area as Skywave Tape Deck Repair. I can get the tape out.
Tascam 238 recording deck won't stop rewinding.
Well which is it 122 mk III or the 238?
The grease in the 122 will harden with time and gear crack or lose teeth. The deck needs to be worked on. There is myself in Chicago,
Russ in New Jersey that are still working Teac Technicians. There is Adrian in CA but I am not sure he wants to work on cassette decks.
Tascam 122 mk III error code
The Tascan 122 Mk III does not have a computer in it to give error codes. I suspect that you have a power supply issue but I can only help you if I see the unit. I am in the Chicago area and run a shop for fixing these decks. I have been doing it for 40 years and have worked at the Teac Factory Service in IL.
[email protected] if you need my help.
The symptoms are recognized as a cracked transport gear that is resolved by a new gear and a transport cleaning and new grease put in. I have done about 6 of them as this is described. I have parts in stock.
1helpful
Left deck doesn't "play" anymore.
There is a mechanism problem in the Pinch Roller part of the deck.
It needs to be looked at by a Technician to correct.
Tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Tascam 102 mark 2 cassette
there is a mechanical problem in your tape deck. probably a losen rubber band. it clicks because the rubber is too lose to move the mechinal parts. so when you power off, it losen the whole machanical parts..it is very easy to replace..opend the deck and check it out..good luck
Top Tascam Audio Players & Recorders Experts
Morne Olivier
Morne Olivier
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
