20 Most Recent
Dell p713w AllInOne InkJet Printer Questions & Answers
Not print magenta or yellow
If you use CISS system. The problem may occur CIS. To solve these follow this proces:1. put out cartrige from cartrige carrier2. put a plastic seringe into the hole of the cartrige and try to out the ink from inside the cartrige ( mainly magenta or yellow)3. Then run a head clean.If result is No Try these:1. Put off cartrige from cartrige Carrier2. find out 4/6 stick inside the carrer3. put a plastic seringe one after and push air on it.4. After that take a seringe with ink and push it gentally into the stick.I think you will be rid from your problem.Thank you.
My printer will not connect
The first step is to set up a wireless network is that you need the
equipments for connection. First of all you need a Broadband Internet
connection, Wireless router, and a wireless network adapter. The router
converts the signals coming from your Internet connection into a
wireless broadcast. You need to purchase an adapter for a desktop
computer and you must make sure that you have one adapter for every
computer. If you have a desktop computer make sure that you have an USB
port to plug the wireless network adapter to your computer.
Paper jammed in Dell 713W
There is a Paper empty sensor (black paddle) on the right side. It is about 1/4 of from the right edge of the paper. It senses the paper and it gets toggled when the paper goes through. Sometime the paddle comes loose or breaks. from a previous paper jam. Look at it with a flashlight..push it back and it should toggle the switch and retun to it proper position. I’m happy to assist further over the phone at
https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Printer head problem. I followed the directions
Hello and welcomeFollow the given instruction to solve print head problem:
- Turn on the hot water until warm
- Put about 1/2 inches of water in a cup
- Put the print head portion (where the ink comes out) in for about a minute
- Dry off the cartridge using a soft tissue.
- Re-insert the cartridge into the printer.
- Run the normal cleaning software routine a few times
Your Rating As Four Thumbs which are given below to this solution will appreciate me
Thanks
Dell 1350cnw printer paper jam
Not sure if this will help, but I resolved mine in the end by opening the toner compartment and removing all of them then popping them back in. I also 'scrubbed' some sensors via a blue pullout bar in the toner area.When I started up the printer, I then held down the Red X button until it said 'ready to print'. It's working fine now.HTH,Tony
