Question about Dell p713w AllInOne InkJet Printer
How do I unpause a printer that says it is paused? I can access the Dell Printer Home, check ink levels, print a test page, and even scan to my computer but I can't get it to print. When access devices and printers it says the printer is paused. I'm usung Windows7.
Posted by cjollier on
destom
    New Friend:
  • 126 Answers
Go to control panel -> printers right click on the printer you want and click resume printer
Posted on Mar 04, 2011
Testimonial: "Thanks for your help! I went to Devices and Printers, right clicked on the Dell, clicked on See What's Printing, Right clicked on Printer, and there it was with Pause Printing checked. Unchecked it and my two documents finally printed."
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
What does it mean that printer is on "pause"
This means that print jobs sent to the printer will not print untill the printer is unpaused. This setting is used mainly for maintenance purposes.
To unpause a printer
1.) Left click Start in the bottom left hand corner of the screen
2.) Left click Control Panel
3.) Now, double-click "Devices and Printers" or "Printers and Faxes"
4.) In the Window you will see your printer, double-click your printer
5.) This screen will show you active print jobs, to pause or unpause the printer click File then click "Pause printing"
Hope this helps :)
May 15, 2011 | Epson Stylus C66 Inkjet Printer
V715w does not print color
I am one of the Dell Certified System Expert that work with Dell Printers before.
For this case first is try to check level of Ink.
-Click start or Windows logo.
-Go to All Programs or Programs, then select the printer program folder from the list.
-Select Printer or printer home.
-Choose your printer from the printer drop-down list.
-From the Maintenance tab, Check ink levels.
If the ink level is very low to none replace the ink
If the printer level is ok, try to run the test page to check if it will print colored, if it is the issue is only in the settings of the printer.
here is how to run test print
-From the Maintenance tab, click Clean Cartridges.
For more information about your printer here is the link:
http://support.dell.com/support/edocs/SYSTEMS/PRN_V715w/en/ug/en_ug.pdf
I hope this will help you a lot in resolving your issue.
Thank you for choosing Fixya
Feb 27, 2011 | Dell Office Equipment & Supplies
Printer will scan but not print
Check whether you have installed the drives correctly. Check the ink levels. Print a test page. Check the cable as well.
May 28, 2010 | Dell 810 All-In-One InkJet Printer
Can't print and when i did got green color
Check the level of your black ink. Double click on your printer icon. This should bring up Dell solution center. Click maintenance and it show the level of your black and color ink. If it appears you have black ink you might try clicking on your menu file, print click on preferences, check print black and white only. If you don't get a printed page. You're for sure out of black ink.
If you get a black printed copy, Double click on your printer icon, click on the maintenance tool to clean and test nozzles.
Jul 01, 2009 | Dell A920 InkJet Printer
Reset ink levels on dell 944
If you refilled the cartridges, you may want to try new Dell branded cartridges.
May 27, 2009 | Dell 944 All-In-One InkJet Printer
Reset the ink memory level after replacing cartridge
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
-Mustafa
Apr 30, 2009 | Dell 962 Photo All-In-One InkJet Printer
Skipping while printing
STEP: Disconnect and Reconnect the Printer Power Supply
Additional Information
1.
Unplug the power cord from the wall socket.
2.
Disconnect the power supply from the back of the printer.
3.
Wait 15 seconds.
4.
Reconnect the power supply to the back of the printer.
5.
Plug the power cord back into the wall socket.
STEP: Perform a nozzle clean on the printer.
The following steps will guide you through running a nozzle clean on the 922 printer:
1. Press the Scan Button and the Up Button at the same time to enter diagnostic mode.
2. Use the Up Button or Down Button to navigate to Clean on the LCD and press Menu to begin the nozzle clean.
3. Check the nozzle clean printout and make sure that it is clear of defects and that all expected color bars exist on the page.
STEP: Clear NVRAM on the 922 Printer
1.
2.
Use the Up Button or the Down Button to navigate to the option for Clear NVRAM on the LCD and press Menu to confirm.
3.
Press Menu again when asked if you are sure.
4.
Press Menu again when asked if you are really sure.
Ink Cartridge and Print Quality Issues on Inkjet Printer
STEP: Verify the Paper Settings and Change the Quality Level
1. Click the Start button, point to Control Panel, and then click the Printers and Other Hardware menu item.
2. Click the Printers and Faxes menu item.
3. Right-click the Dell AIO Printer Model Number icon, where Model Number is the model of the printer to troubleshoot.
4. Click the Properties menu and the Printing Preferences menu option.
5. Click the Quality/Copies tab.
6. Click the Paper Setup button.
7. Choose the appropriate paper type based on what is being used in the printer.
STEP: Verify the Printer Ink Levels
Quality problems are most often caused by low ink levels or one or more colors in the color cartridge being completely depleted. Perform the following steps to determine the current ink levels and to check for missing colors.
1. Click the Start button, point to All Programs, and then click Dell Printers.
2. Click the model number of your Dell printer.
3. Click Dell Printer Solution Center.
4. On the main window of the solution center you will see two ink tanks in the lower right hand corner. Verify that the ink cartridges are not empty
To ensure that the quality problem is not caused by one color missing print a test page and verify that the colors in the CMYK boxes appear correct. To do so, perform the following actions from the solution center window:
1. Click the Maintenance button on the left-hand side of the window.
2. Click Print Test Page.
3. Verify that the Cyan, Magenta, Yellow, and blacK colors are printing without streaks.
Apr 22, 2009 | Dell 922 All-In-One InkJet Printer
Paused
Go to the printer properties and un-check "use offline"
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
White horizontal streaks in documents
I Am Experiencing Poor Print Quality With My Dell™ Printer
Table of Contents
Verify the Printer Ink Levels Using the Dell Printer Solution Center
Clean the printer contacts and print a test page
Clean the Printer Nozzles Using the Dell Printer Solution Center
Dell™ Printer Additional Information
» Verify the Printer Ink Levels Using the Dell Printer Solution Center
Poor print quality of a document or picture may be the result of low ink levels or dirty printer nozzles or contacts.
To check the printer's ink levels, perform the following steps:
1.
Click the Start button, point to All Programs, point to Dell Printers, and then point to Dell (printer model).
2.
3.
Locate the printer's ink levels on the lower right corner of the Dell Printer Solution Center window.
4.
If the printer's ink levels indicate that ink cartridges are empty, click the Order Ink button to place an online order for replacement ink cartridges.
For information about ordering ink for your Dell printer, refer to article: Obtaining Ink for a Dell™ Printer
Back to Top
» Clean the printer contacts and print a test page
To manually clean the printer nozzles and contacts, perform the following steps:
1.
Turn the printer off and remove the power cord from the back of the printer.
2.
Open the printer lid.
3.
Manually move the ink-cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right hand side of the printer.
4.
Take a warm, semi-damp paper towel and gently clean the wiper on the right side of the maintenance station.
5.
Lift up on the cap(s) that cover the ink cartridge(s).
6.
Remove the ink cartridge(s), and using a new warm, semi-damp paper towel, gently clean the contacts on the ink cartridge(s).
Verify that the contacts on the ink cartridge(s) is/are sufficiently dry prior to re-inserting into the printer.
7.
Re-insert the ink cartridge(s) back into the correct printer slot(s).
7.
Close the printer lid.
8.
Re-attach the printer power cord to the back of the printer unit.
9.
Press the Power button to turn the unit back on.
10.
11.
12.
Click the Maintenance tab.
13.
Click the Print a test page icon.
A test page prints.
Back to Top
» Clean the Printer Nozzles Using the Dell Printer Solution Center
To clean the printer nozzles and contacts using the Dell Printer Solution Center:
1.
2.
3.
4.
Click the Clean to fix horizontal streaks icon.
5.
Click the Print button.
Note:
The printer will make sounds when cleaning the nozzles that are not commonly heard during normal usage
Mar 19, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell p713w AllInOne InkJet Printer Logo
1,419 people viewed this question
Top Dell Office Equipment & Supplies Experts
Richard C Cohen
Richard C Cohen
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
