20 Most Recent
AMD Athlon 64 X2 4600+, 2.4 GHz (ADA4600BVBOX) Processor in a Box (PIB) Questions & Answers
E2180 Vs Athlon 64 X2 5000+
depends on what you plan to do with the cpu amd are good but a 3200 may only run @ 1.8 to 3.2 ghz depending while a intel 3200 will run 3.2 ghz.
I believe intel are more stable & run cooler than AMD but AMD benchmarks on Games better but run hotter (so get a good cooling fan & heatsink both pentium / celeron d & intel dou / dual core / core 2 dou and amd x2 have 2 cores (but watch your front side bus and cache the higher the better but the more $ also) then You need a good stable mobo that supports the chip you get (I preffer asus & msi for Gamers and biostar / msi for home users)
Where do I start computer upgrade
Your machine is very short of power required for win 10, I would like to see at least 8 GB ram, and a faster processor, yours is at the bottom of tests. Perhaps you should look at a new machine with win 10 installed. You cannot upgrade xp to win 10. You will have to purchase a win 10 license, you missed the free upgrade period.
On my Back-ups ES 550 the "Building Wiring Fault"
This red light usually indicated the ground on the outlet the UPS is connected to is not properly connected to ground.
It could also mean the ground and neutral wires on the connected outlet are reversed.
