20 Most Recent
HP Laserjet P4515x Printer Questions & Answers
Standard_top_bin_full_remove laserjet p4515x
The black lever where the paper comes out (right side) is stuck down, lift up to unstick.
this is temp. will stick again unless you clean it.
remove 4 screws undo the white lever that is attached to door
(right side)
lift up top
put upside down
look at black lever
there is a pad that has melted and is sticky
clean ( remove is best with flat screw driver) then clean
put back together.
solved
Ip address change
Press "Menu"
Scroll to "IO sub menu" Enter
Scroll to "TCP/IP" Enter
Scroll to "Manual settings" Enter
You can see the saved IP address, it can be change, enter desire IP address...enter for save the changes....back to main menu..
To confirm: (You can follow the above said method to see the saved IP) OR
Press "Menu"
Scroll to "Information menu" Enter
Scroll to "Print menu map" Enter
Printer prints menu map, you cam see the entered IP address here, if you found its success, if not try once again..
Maintenance reset
Reset the maintenance-kit counter1. Turn the product power off and then on.2. When XXX MB appears on the control-panel display, press and hold down the OK button until all three control-panel lights flash once, and then stay on. This might take up to 10 seconds.3. Release the OK button and press the up arrow to scroll to NEW MAINTENANCE KIT.4. Press OK to reset the maintenance-kit counter.
I installed the printer and
This is the HP solution for the problem
HP LaserJet, Color LaserJet and LaserJet MFP Products - Print driver Client / Server Connections in a mixed 32-bit and 64-bit environment
ISSUE: 32-bit clients are not able to connect to shared Universal Print drivers or discrete drivers on a 64-bit print server or vice-versa. These scenarios may involve Server 2003/Server 2008 64-bit print servers with Windows XP, Vista, 7 32-bit clients. It is also possible that the server editions could be 32-bit versions with 64-bit clients.
SOLUTION:
The administrator will need to download the 64-bit AND 32-bt version of the print driver from www.hp.com . If the server involved is a 64-bit version, the 64-bit version of the print driver will need to be installed and mapped to the printer via TCP/IP. Ensure that the print driver has been shared on the network by going to the print driver properties and enabling Share this printer within the Sharing tab.
Ensure that communication has been established and that a driver test page can be printed from the 64-bit server. Once functionality has been confirmed from the 64-bit server, proceed to the next step.
Currently, 64-bit clients will be able to connect to the shared 64-bit print driver that has been installed on the 64-bit server as the architecture currently matches. However, if 32-bit clients wish to map to the shared 64-bit print driver on the 64-bit server, the 32-bit version of the same driver will need to be installed within the current 64-bit driver.
This process can be done by navigating to the printer properties of the 64-bit driver on the 64-bit server, clicking the Sharing tab and clicking the Additional Drivers button.
Once the administrator clicks on the Additional Drivers button, the next screen will allow the administrator to load the 32-bit drivers by placing a checkmark in the x86 button and clicking the OK button.
Once the administrator clicks the OK button, a print driver window will pop-up asking for the 32-bit driver components. Again, the administrator will need to download, and extract the 32-bit version of the print driver on the 64-bit server. Once the window below comes up, the administrator will need to navigate to the 32-bit driver components and select the appropriate driver .inf file.
For example, the UPD .inf file would be the first file in the list and be named hpcuXXXc.inf.
Once the appropriate .inf file is selected, the 32-bit driver components will be installed within the 64-bit driver on the 64-bit server. This can be verified as both x86 (32-Bit) and x64 (64-Bit) boxes will now be checked and show the status as installed by clicking the Additional Drivers button compared to the screenshot in Step 3 above.
Now that 64-Bit and 32-Bit drivers have been loaded onto the 64-Bit server, 32-Bit and 64-Bit clients can now navigate to the shared print driver on the 64-Bit server, by manually navigating to the shared print driver on the 64-Bit server from the client machine. Typically the path is \\servername\sharedprintername.
Once the client maps to the shared print driver, printing should work successfully.
For problems or errors that continue to occur after completing the aforementioned process, ensure that the latest version of the print drivers are being used www.hp.com . If there are problems with older discrete drivers, it is recommended to use the latest version of the Universal Print Driver which can be found at www.hp.com/go/upd .
I had a paper jam
Pull out the powercable and leave it out for several minutes. Then plug it back in. See if somthing happens now.
Hp laser jet printer 2055 ,52 scanner error how can solve it please
The HP Printer error 52 indicates with scanner. When you see the HP printer error code 52, then follow the steps:
·Turn off the printer
·Wait for 30 seconds and then turn on the printer
·In case the 52 error is still coming up on the printer, then make sure that the Flatbed scanner assembly is replaced
·In case the error is still being shown, the Scanner/Laser assembly may also require replacement.
Find the more HP printer error codes and their solutions. If you need any help to fix the issue contact HP Printer experts.
HP LaserJet pro color MFP M276N Network lan port no working
Troubleshoot the wired network connection
Make sure you are using an undamaged Ethernet cable, check for a green light near the Ethernet port on the printer, and then print a report to verify the connection.
Turn off the printer, and then disconnect the Ethernet cable from the router and the printer.
Check the cable for damage, and then verify that it is an Ethernet cable and not a phone cable.
NOTE: Ethernet and phone cables look similar, but Ethernet cables are usually bigger and have eight visible wires on the connector.
Reconnect the cable to a different Ethernet or LAN port on the router, and then connect the other end to the printer's Ethernet port.
Turn on the printer.
Check the lights on the printer's Ethernet port to make sure the connection is successful. The green light should be steady, and the orange activity light should blink.
Print a Wireless Network Test Results or Network Configuration report.
Inkjet printers with a control panel menu: Open the Wireless, Network Settings, or Setup menu to locate the list of available reports.
Most inkjet printers without a control panel menu: Press the Wireless and Information buttons at the same time, or press the Wireless and Start Copy Black buttons at the same time.
LaserJet printers: Press and hold the Wireless button for 10 seconds or until the Ready light blinks, or go to the Wireless menu and select Wireless Network Test.
Laser NS and Neverstop Laser printers: Press and hold the Resume and Wireless buttons for 3 seconds.
DeskJet 6000 and 6400, ENVY 6000 and 6400, and Tango printers: Touch and hold the Information button until all control panel buttons light up, and then touch the Information and Resume buttons at the same time.
Make sure the Network Status is Ready, or follow any instructions to resolve network issues identified on the report.
Regards,
Rachel Gomez
How to clear memory on HP P3015
Before starting, note down the IP address if its network printer..
1. Turn the product off.
2. Turn the product on. When the memory count begins, press and hold the OK button. Continue holding down the OK button until all three product control-panel lights flash once and then remain on. This might take up to 10 seconds.
3. After the message SELECT LANGUAGE appears on the display, press the button or the button until COLD RESET is highlighted.
4. Press the OK button. The product performs a cold reset and then continues its power-on sequence.
5.Chk & set I/O settings..if required..
