Question about HP LaserJet Office Equipment & Supplies
13.B2.D3 laserjet 4555 mfp keeps happening
Keep removing the paper it stops right after leaving tray 3 or 4, replaced all the rollers
5 Related Answers
Anonymous
SOURCE: Paper jammed in printer - need to remove paper tray
1 This works from HP help link in error message:
Turn off the HP All-in-One.
2 Press in the tab on the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. icon_caution_color.gif Caution Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
Posted on Jul 29, 2008
Anonymous
SOURCE: hp laserjet 8100 8150 13.1.42
hp printers typically do not have an error message to cover every known condition, thus if the printer needs maintenance in an undefined area, it will invariably indicate a paper jam. The printer usually responds to the installation of a maintenance kit which will include transfer roller, pickup rollers, and fuser.
Posted on Oct 03, 2008
Anonymous
SOURCE: laserjet 4345 mfp paper jam
13.20.00 can be also caused be a jam near the fuser (the part of the printer that gets hot to make the toner stick to the paper). Remove the toner cartridge and take a look for small scraps of paper along the whole path. Also open the door on the back of the printer and look for paper scraps from there. If you see paper stuck in the fuser, do not use anything sharp to remove it, be careful not to scratch the surfaces.
Posted on Oct 08, 2008
Anonymous
  • 240 Answers
SOURCE: default paper tray selection for HP LaserJet 4200tn
1) When the printer receives a print job, it selects the tray by trying to match the requested paper type and size with what has been loaded in the trays. Using an “autoselect” process, it searches all available trays for the paper that satisfies the request, starting with the bottom tray and ending with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/size.
2) If paper is loaded in tray 1 and tray 1 is set "TRAY 1 TYPE=ANY" and "TRAY 1 SIZE=ANY" on the
Paper Handling menu, the printer will always pull paper from tray 1 first.
Posted on Dec 10, 2009
Anonymous
SOURCE: paper jam inside HP Color Laserjet CM1312 MFP, not
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Posted on Oct 12, 2010
My pictures are coming out with pink or purple streaks. Every time I print a picture, the streaks are in different places, all going from bottom left to top right . I have changed the ink roll and the...
Try cleaning the paint roller.
6 Care and maintenance
Cleaning the paper feed roller To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the paper feed roller clean. Inspect the roller weekly for debris particles, and clean if necessary.
IMPORTANT: Unplug the power before cleaning the paper feed roller.
spacer.gif spacer.gif spacer.gif spacer.gif 1.Unplug the AC power cord from the power outlet.
2.Remove the paper tray from the photo printer, and leave the paper tray door open.
3.Lightly moisten a lint-free cloth with water.
IMPORTANT: Do not use cotton or cotton swabs to clean the paper feed roller.
autourg00462006id1604162.jpg 4.Use the moistened cloth to gently wipe clean the surface of the paper feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
5.Allow the paper feed roller to fully dry before reconnecting the power.
Click below for the complete manual:
Kodak EasyShare Photo Printer 500 Manual
Hope this helps.
Zeppelinx12
Mar 11, 2011 | Kodak EasyShare Photo Printer 500
Im using ricoh 2045..Paper jam occurs at point A1 (the lever the drops to remove the paper) . I have noticed roller A1 and registration roller doesn't rotate. When i remove the paper and close the covers...
this is not a thought I am 100% sure and give you the correct solution:
problem with the paper feeding section is dusty or due to developer drooping
1. Open the developer unit and check the rear side developer unit bush one or two bush are faulty
and drop the developer.
2. remove all paper trays with remove the four each screws
3. Remove the toner collection bottle
4. Remove the right side cover.
5. Remove paper left roller plate.(show in the picture)
6. Now remove the first tray paper feeding section(is a complete unit included paper feed rollers motor and clutch and gear section)
7. Clean the drooped developer from all gears and roller and motor section
8. remove the second and third tray paper feeding section and doing the same.
9. now fix it all
10. replace developer unit bush witch are faulty or if you don't have yet cut a plastic sheet and past the upper side of first paper feeding unit gears witch are don't disturb the paper path and stop the developer drooping on the gear good_help.pnggood_help_0.png
Jan 27, 2011 | Ricoh Aficio 450 Copier
Misfeed in tray one with no misfed paper. The machine is trying to grad from tray one but cant.
Pull out your paper tray (instructions below) and make sure there's not paper behind the tray blocking the motors from operating.
Else, worn rollers or broken lift motor.
First go to the service sim mode with the key combo # * C *
Type 22 - Start 9 - Start
If your tray 1 counter is above 100,000 your 3 rollers need to be changed. This is easily done by taking out the tray (you must tilt to the left and lift up at the end), unclipping and removing the paper guide, and unclipping and removing the 3 paper tires.
If your counter is under 100K try washing your rollers with soap and water, rubber cleaner and alcohol if you have it, but not Windex or 409. Your matched set of feed/sep tires should have some rough tread on them, if they are baby **** smooth its' replacement time.
If it pulls paper from a fresh stack and then stops pulling after a few sheets, the motor that continunally lifts the paper stack to meet the rollers has broken down, and can be replaced from the back of the machine.
Dec 30, 2010 | Sharp MX-3501N All-In-One Printer
Paper will not feed Gestetner 5325
check the paper tray end stop ie the green tab that keeps the paper in the tray as these can come out or be moved.. when you load paper make sure the green tab is tight against the paper.. also the feed rollers might need replacing.. if you take the tray out and then look inside the opening to the right hand of the opening you will see some grey rollers or it may be one large roller this can be removed and cleaned.. the small type have a litle white clip holding in place.. if you have the large roller there is a plastic black lever towards the fron on the top right that has to be moved out to the front then you can remove the roller and clean..Good luck let me know if you need more info
Oct 19, 2009 | Gestetner Office Equipment & Supplies
I have connected up all leads , cartridges and instalation as per manual. the printer turns on but will not get the paper moving.
Hello
here are the steps.
1. Remove the paper from the paper tray.
2. Fan the stack of pape
3. Open and fully extend the paper tray.
4.Load paper into the paper tray.
5.Align the paper with the dotted alignment lines on the paper tray, then adjust the paper guides until they lightly touch the paper.
If issue persists,
1.Disconnect the following from the back of your printer:
* AC power cord
* USB cable
3.Remove the paper from the paper tray.
4.Remove foreign objects or debris from the paper tray. 5.You may need a flashlight to view the back of the tray.
6.Open the access cover for the printer
7.Remove foreign objects or debris from the paper path. 8.You may need a flashlight to view the paper path.
9.Remove the cleanout assembly from the rear cleanout area:
a.Gently press and hold the tab on the left side of the cleanout assembly.
b. Carefully pivot the left side of the cleanout assembly toward you to remove it.
10.Lightly moisten a lint-free cloth with water, then gently clean the surface of the feed rollers. Advance the feed rollers with your thumb, and continue cleaning.
11.Allow the feed rollers are completely dry.
12. Install the cleanout assembly.
a.Insert the right side of the cleanout assembly - 1 into the back of the printer so that the tabs - 2 fit into the slots on the right side of the cleanout area.
b.Rotate the left side of the cleanout assembly until the latch - 3 snaps into place.
c.Pull on the cleanout assembly to insure that it is seated.
13.Connect the following to the back of your printer:
* AC power cord
* USB cable
14.Wait 30 seconds, then turn on your printer.
15.Pull the paper tray all the way out until the paper 16.Squeeze and move the paper-width guide to the left.
17.Fan the stack of paper and load it into the paper tray.
18.Squeeze and move the paper-width guide to the right until it touches the stack of paper.
19.Lift the small gray paper stop until it is perpendicular to the paper tray.
20. Make a print
If issue persists, the printer itself needs to be replaced. Call 1.800.421.6699
Thanks
Sep 25, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Only prints half way and doesn't grab paper right away
Here are the steps:
1.Remove the power cable from the printer.
2.Remove the paper tray from the printer and leave the
of the roller.
5.Let the feed roller dry before plugging back the AC
power cord
6. Fan the paper to keep the sheets from sticking
together.
7.Place 15 - 20 sheets of paper into the paper tray
8.Insert the paper tray into the printer.
9. Make a print.
If issue persists, call 1.800.235.6325 for repair.
Sep 24, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
I have an Easy Share printer dock series 3 that has paper loaded
To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the feed roller clean. IMPORTANT: Unplug the power before cleaning the feed rollers.
  1. Unplug the AC power cord from the power outlet.
  2. Remove the paper tray from the printer, and leave the paper tray door open. IMPORTANT: Do not use cotton or cotton swabs to clean the feed roller.
  3. Lightly moisten a lint-free cloth with water.
  4. Use the moistened cloth to gently wipe clean the surface of the feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
  5. Let the feed roller dry fully before plugging the AC power cord back into the power outlet.
  6. Insert the paper tray into the printer, then press the Print button to resume printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 26, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
AR 200- paper pulls to the green bar and then stops- will not print or move from there and screen says to clear paper path. no paper moves beyond the same point.
This "green bar" (registration roller) could be a few things
  1. Registration sensor dirty or inoperable
  2. Feed tires dirty
  3. Registration rollers dirty
  4. Fuser gate broken
For item 1 the flag and sensor is located under the copier. if you only have one tray then this can be located and removed easily. if you have 2 trays then this get more difficult. Here are the steps for one tray
  1. Open and remove right side door
  2. Remove toner, developer, and drum unit
  3. Remove paper tray
  4. Turn copier on its right side
  5. (Top is away from table and bottom is towards table) Towards the bottom of the copier there is a guide that needs to be removed (2 screws)
  6. There is a cover where a couple of wires are going to needs to be removed (use caution)
  7. Once removed take can of air and blow out sensor
  8. Replace items as removed
For item 2 follow steps 1-4 and locate tires clean using warm soapy water on a lint free cloth or mechanics towel
For item 3 open and remove right side door and clean grey rollers located under green cylinder which is your drum (USE caution not to touch or damage)
If the first 3 steps do not help then you should call your local Sharp dealer for repairs.
Mar 17, 2009 | Sharp Office Equipment & Supplies
Paper catch rollers out of alignment
Hi.
Try this
1.take a sheet of paper ,,fold it length wise 2-3 times to make it thick.insert this into the paper feed tray...move it left and right a couple of times..this clears the obstruction if any..
if this does not work..call lexmark tech support,,,your printer would be replaced if in warranty..
good luck
Jan 25, 2009 | Lexmark X5470 All-In-One InkJet Printer
Printing problem with HP Laserjet P2015 printer
This can be an issue with one of the faulty sensor across the printer.
Please check if you are able to print from tray 1, e.g. a configuration page.
A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
Figure 1: Unplugging the power cord
mma01_13245_0
2. Open the print cartridge door, and remove the print cartridge.
Figure 2: Removing the print cartridge
mma01_13246_0
3. Remove the main input tray (Tray 2).
Figure 3: Removing the main input tray (tray 2)
mma01_13247_0
4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only).
Figure 4: Opening automatic two-sided path door
mma01_13248_0
5.Place the printer on the work surface with the front of the printer facing up.
Figure 5: Placement of printer
mma01_13249_0
6. Pull the white tabs outward, and rotate the tabs up.
Figure 6: White tabs
mma01_13250_0
7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
Figure 7: Right tab movement
mma01_13251_0
8. Slide the pickup roller assembly to the right, and remove the left end cap.
Figure 8: Pickup roller assembly movement
mma01_13252_0
9. Remove the pickup roller.
Figure 9: Pickup roller
mma01_13253_0
10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the right slot (2).
mma01_13254_0
11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
Figure 11: Pickup roller end cap
mma01_13255_0
13.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer facing up. 15.Close the front automatic two-sided path door.
Figure 12: Closed automatic two-sided path door
mma01_13256_0
16.Reinstall the print cartridge, and close the print cartridge door.
Figure 13: Print cartridge
mma01_13257_0
17.Plug the printer in to turn it back on.
Figure 14: Power cord in
mma01_13258_0
Cleaning the pickup roller
Perform the following to clean the pickup roller.
1.Remove the pickup roller as described in steps 1 through 9 of Replacing the pickup roller above.
2. Dab a lint-free cloth in water, and scrub the roller.
mma01_13259_0
Figure 15: Scrubbing the roller
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
mma01_13260_0
4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
mma01_13261_0
Figure 17: Reinstalling the pickup roller
Oct 27, 2008 | HP LaserJet P2015dn Printer
187 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
