Question about HP LaserJet Office Equipment & Supplies
Laserjet pro 400 color has jam in out put bin but no paper in that area. Don't know where the sensor is and how to test it. can you help?
Posted by Jerry Fowler on
4 Related Answers
Priya darshan
  • 3422 Answers
SOURCE: Paper Jam errror
Jam in output bin - duplex area
Error message
Jam in output bin
alternates with
Open door and clear jam
Description
Paper jam in duplex reversing area
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Jam in output bin - fuser area
Error message
Jam in output bin
alternates with
Description
A paper jam has occurred in the output bin near the fuser area.
Action
  1. Clear the jam.
Goodluck..
Posted on May 14, 2008
Anonymous
  • 192 Answers
SOURCE: A HP Color Laserjet 3000n has the following errors
Perry,
Usually I have found that there is a scrunched up piece or bit of paper in the fuser.
I am adding a link below that will take you through the step-by-step process and you should find the source of the problem. Be careful when touching the fuser that thing gets HOT!!
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00506722
Please let me know if this has helped and if i can help you any further.
Thanks
Posted on Mar 31, 2011
Terry Corrow
johnny rebel
  • 10875 Answers
SOURCE: jam in out put bin
CONTACT hp
Posted on May 11, 2015
Testimonial: "they are not helping"
richie46
  • 12962 Answers
SOURCE: Hp LaserJet Pro 400 paper jam in cartridge area
Clean all of the rubber feeders with alcohol/rubber restorer in the paper path of printer.
Posted on Sep 14, 2016
Testimonial: "I will give that a try. Thank you."
Sep 14, 2016 | HP Laserjet Pro 400 Mfp M425dn...
Paper Jam errror
Error message
Jam in output bin
alternates with
Description
Action
  1. Clear the jam.
Error message
Jam in output bin
alternates with
Description
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
My laserjet pro 400 color mpf m475dn printer is indicating " paper jam...open back door to clear jam," please describe how i will go about this process.
There is an access door in the back of the printer. Open the door and you should see jammed paper. If not then you have a faulty sensor or switch.
Mar 20, 2014 | HP LASERJET PRO 400 COLOR MFP M475DN
Hp laserjet pro 400 M451NW paper jam in tray 1
I find a cover of the registration sensor stop the actuator I cut and working good
Jan 30, 2014 | HP LaserJet Pro 400 M451nw Workgroup Color...
Says I have a paper jam but don't
Remove fuser assembly mounted on the top, check paper input & out put sensors clean or blow air on it to clean the dust, if found any sensor flag dis located, locate it properly, if found damaged replace fuser unit..
Feb 01, 2012 | HP Color LaserJet 3500 Printer
Can't find the paper that is jammed in the printer (laserjet 2600n) its says its in the output bin
The output bin sensor check the quantity of printed paper that remain in the upper part of the printer. When the paper is too much, the sensor report a paper jam.
Check the lever of the sensor in output bin if it's working properly
Jun 15, 2011 | HP Color LaserJet 2600n Printer
Display reads - " jam in output bin " jam was
look at the output area, make sure that the paper lever is working. Sometimes they come loose after a jam.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 21, 2010 | HP Laserjet CM 1312NFI Color Printer
My HP Color Laserjet 3600n had a paper jam. The
Your best method of troubleshooting is the manual sensor test as this is a generic paper jam error.
on your sensor tests:
0 = off
1 = on
A = TOP OF PAGE SENSOR
B = PAPER LOOP SENSOR
C = N/A
D = FUSER PAPER SENSOR
E = DELIVERY-TRAY PAPER-FULL SENSOR
F = FUSER PRESSURE-RELEASE SENSOR
G = MEDIA SENSOR
H = N/A
I = MP TRAY SENSOR
J = CASSETTE SENSOR
K = DOOR OPEN DETECTION SWITCH
L = DEVELOPING ESTRANGEMENT SENSOR - CLR
M = DEVELOPING ESTRANGEMENT SENSOR - BLK
N = MP TRAY MEDIA POSITION SENSOR
A-F are paper path sensors - you can toggle them and watch if they change from 0 to 1. If they do, the problem is not in that area.
G can have states from 0-7 each one representing a different type of paper - shouldn't have anything to do with jamming.
hope this helps. probably a tiny piece of paper or toner somewhere. could also be a torsion spring out of position on a flag.
May 10, 2010 | HP Color LaserJet 3500 Printer
My printer says there is a jam in the output bin but there is no visable jam. HP color laserjet 2600n
Just try the steps
Jam in output bin - fuser area Error messageJam in output binalternates withOpen door and clear jam DescriptionA paper jam has occurred in the output bin near the fuser area. Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.
Jam in output bin - duplex area Error messageJam in output binalternates withOpen door and clear jam DescriptionPaper jam in duplex reversing area Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.Please Rate my response!!!Thanks, SF
Jan 28, 2010 | HP Color LaserJet 2600n Printer
4600 color replaced fuser get paper jam error
Check fuser for broken tabs that would engage sensors.
clean 3 sensors behind fuser with a blowerbrush or makeup brush.
make sure you did not break output full bin arm on back of fuser{happens a lot}.
need more help? just ask.
Aug 14, 2008 | HP LaserJet 4600dn Color Printer
1,279 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
