I had the same issue. Mine was due to a broken plastic piece that holds the flapper. In my case it looks like there is not a easy fix. Take it apart and check for missing peices
SOURCE: ice and water dispenser for Maytag H20 not working
You need a new high voltage control board. Ive had at least 10 do this.
SOURCE: No water or ice through door
I had the same problem. Trap door in fridge door opens, but trap door between freezer and fridge was coated in frost, so didn't open. Scrape off ice from flap (located under where the control buttons are - look up there and you'll see it!) and bingo! Fixed.
SOURCE: maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
SOURCE: Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
