water and ice side does not dispense. water pipe was broken and fixed now the dispensers are not...
(More)
water and ice side does not dispense. water pipe was broken and fixed now the dispensers are not working. the initial problem was the freezer side was leaking. now the freezer no longer leaks
leaks water from both side of the refrigerator, but not necessarily at the same time. The drain pan...
(More)
leaks water from both side of the refrigerator, but not necessarily at the same time. The drain pan is dry and the whole botom of the refrigerator appears to be dry. I have found ice in the condencer radiator, and the drain that is located just below the radiator is pluged with ice. Of corse this has lead to ice accumilation in the bottom of the freezer to the point of freezing the drawer tray in place a few times. We have deiced this area each time, this time I decided to investigate the situation further and found the radiator iced up. My question to you is, and I believe I already know, could this cause the leaking under the refrigerator?
I am using a two year old maytag side by side refrigirator with the model# MZD2667HIS. After...
(More)
I am using a two year old maytag side by side refrigirator with the model# MZD2667HIS. After changing the filter the water pressure had reduced by half. I tested the water pressure with no filter using the cap and it is three to four times faster than with the filter. I tried with a second new filter and also with the old filter and the pressure is very low. what is changing after placing the filter for the water pressure to drop? Please help me. Thanks
We replaced the freezer door assembly but the ice is getting stuck in the door chute. Could this be...
(More)
We replaced the freezer door assembly but the ice is getting stuck in the door chute. Could this be the spring is on incorrectly?
my maytag side by side clicks on and makes a loud humming noise for about 5-6 seconds then makes a...
(More)
my maytag side by side clicks on and makes a loud humming noise for about 5-6 seconds then makes a loud click Its gotten more frequent in the last couple days
Many face the problem of bad odor in refrigerators. Here are few simple tricks to get the problem of bad odor solved:
Keep an open box of baking...
written by techbuster
I had water leaking in to the freezer compartment of my LG french-door refrigerator (LFD25860). It was getting on to food in the main basket and...
written by Tall Peter
I installed a surge protector on the electrical outlet that powers my LG refrigerator as recommended by the repair tech after my first warranty repair...
written by jmorganti
Many people often stress over laying a refrigerator or freezer down in the back of a truck in order to move it. It has happened many, many, times that...
written by MrMark52
Refrigerator not cooling, ice forming on back of side-by-side freezer: Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to...
written by h_loberg
Try
using an hairdryer or defrosting the unit completely , this often get
rid of blockage caused by frozen lines fixing the problem.
The water...
written by ginko
Have you noticed that when you open the freezer door that you hear a fan running? That's the evaporator fan. When that fan motor goes bad, you'll...
written by SolutionGuy
If you just gotta know how old your appliance is, do this: When you have the full model and serial number (all numbers, all letters) point your web...
written by meyerjr
Defrost your freezer quickly! Steps 1. Turn the freezer off (unplug it). 2. Take out all the food. 3. If required, unscrew the inside-back of the...
by wikihow
If you have a horrible smell in your refrigerator that you can't seem to get rid of, follow these steps to make it history. Even rotten meat has no...
by wikihow
Every so often, a refrigerator needs to be cleaned inside. The shelves have to be washed down from milk spills, and food tossed out if they have...
by wikihow
Fixing a refrigerator is easier then you think. If the light is on, but nothing else works, here's what you can do.
Steps:
1. Check that the knob is...
by wikihow
