Model MSD2542VEW01 refridgerator The Problem with the Maytag Refrigerators model MSD2542VEW01 refridgerator The ice bin has ice on the outside, front left & the part on the bin where the ice comes out gets frozen over. Have to clear it every 2 to 3 days or ice will not dispense. Unit only 18 month old. any help would be great, Thank you Sherry
Https://www.repairclinic.com/Shop-For-Parts/a4b4d927131/Model-MSD2542VEW01-Maytag-Refrigerator-Parts
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair/4-4-927131-/Maytag-Refrigerator-MSD2542VEW01-Troubleshooting
See the above links for helpful information on fixing your issues.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
SOURCE: GE SIDE X SIDE Dispenser problem
Sound like maybe a dispenser board short... you could try taking of the top hidge cap on the freezer side unplug the power to the board there for 30 minustes or so plug back in and see if it can reset to default and try that before u have to change board
SOURCE: Ice Maker Issues
HELLO!!!
THIS MAY HELP U ...
http://www.applianceaid.com/icemaker.html#overflowing
SOURCE: Ice maker won't make ice after emptying ice bin manually.
make sure you push the ice lever back down
SOURCE: Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
SOURCE: Ice cubes are frozen but will not eject into the ice bin. I need to know how to get them out.
HI, You can use a hair dryer to the bottom side of the ice maker and it will let the cylce finish and remove the cubes. Can you tell if the cycle has started?
Please let me know if I can assist you further.
Thanks
Vic
