Kenmore Elite Oasis 27052 Top Load Washer Logo
Posted on Aug 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My aunt has a Kenmore Elite range and it begam flashing a "PO" error message. Can you tell me what this means?
Anonymous
Level 3:
  • Master 2,341 Answers
  • Posted on Aug 03, 2011
Anonymous
Master
Level 3:
Answers
2341
Questions
Helped
636858
Points
7414
PO means power outage so if ya has a lighting storm or for some reason if the power went out thats why it says that . Push clear/off for 3 -5 seconds and codes should go out
What does F5 mean on my Kenmore 600 series washing machine
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
Sept 5, 2015
Error code F 05 repair tips please. - Kenmore Elite HE3 ... - iFixit
and may also be the lid lock.
https://www.justanswer.com/appliance/eqv65-kenmore-600s-washer-recently-started.html
My kenmore elite gas range gave a f023 error message?
https://www.shopyourway.com/questions/1040579
Quoting from link shown:
What does F23 error code message mean on Kenmore Elite built-in double ovens? Report This
by Manage My Life
August 17th, 2009 What does F23 error code message mean on Kenmore Elite built-in double ovens? The model number is 790.48143800.
: What does F23 error code message mean on Kenmore Elite built-in double ovens?
Resolution
: Error code
F 23
indicates the control detected a problem with the communication link or can be generated as a result of irregularities in the power supply or usage.
The error code
F23
can often be resolved by removing power to the appliance for a minute and then restoring the power.
By unplugging the appliance it allows the control to receive a fresh supply of power. This in turn will clear the controls memory of any irregularities it may have received from the power supply. Once refreshed the error should no longer be displayed.
Unplug the unit or turn the circuit breaker off for 60 seconds.
Restore the power to the appliance by plugging it back in or turning the circuit breaker back on.
Check to see if the error code is still displayed on the range.
Run the appliance in the cycle that initially caused the error or attempt to turn on broiler.
If the error code is displayed, then service is needed.
Note
: General resolution for problem is based on information submitted with question. If problem persist, contact a service technician to
Sears Repair Department 1-800-469-4663
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
cycling power may reset this
Jan 30, 2016 • Dryers
2answers
My Kenmore Elite Oasis HE is flashing a code "F50", can you tell me what the error code means?
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
What does the blinking lights mean when it flashes "F" then "02"?
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch
I have a Kenmore Elite slide in range. The stovetop works fine along with the twist knobs. But the touchpad buttons and the oven doesn't work at all. When i tried unpluging it to reset it, it flashes an...
The F30 error code means the temperature sensor probe is open. First check the wiring, then check the probe. And if necessary, switch to a meat thermometer instead of a sensor probe. F31 is the error for a shorted temperature sensor probe.
2answers
KENMORE ELITE CALYPSO
Call Kenmore if you bought it new they may have a record of your serial number and be able to tell you what the error message means and if you need a service call to fix or you can do it yourself. my serial number is on the back of the washer on a sticker or a typed silver tag that is attached to the washer.
3answers
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
Alexander
vince
