Televison & Video Logo
Anonymous Posted on Jul 11, 2011
Not sure if anyone has come across this problem before. I have had 3 tv's in my son's room and all 3 different models including old one alba 19 inch lcd and another all just stopped working. Changed fuse in plugs and still nothing. Now my Alba lcd32880hdf downstairs in the living room has done exactly the same thing changed the fuse and still nothing, opened all tele's up and does not seem to be a seeable fault. Lcd in my bedroom and daughters bedroom are ok. Any solutions or any direction would be much appreciated as it is getting expensive. 19inch was new not even month old and 32inch alba is 1 1/2 years old
  • Anonymous Jul 11, 2011
    thank you I was thinking something with the wiring as it never happened before until they rewired the whole house
Joe LeBlond
Level 2:
Habit-Forming:
  • Expert 146 Answers
  • Posted on Jul 11, 2011
Joe LeBlond
Expert
Level 2:
Habit-Forming:
Answers
146
Questions
Helped
43385
Points
431
Jotvguy just wondering, is there definitely power in these outlets ? Have you tried a lamp or something else to prove you have power at the wall outlet?
  • 1 more comment
    yes everything else works in the sockets all around the house
  • Joe LeBlond
    Joe LeBlond Jul 11, 2011
    Very strange, perhaps a lightning strike nearby but to have so many tv's all fail at once, I would think this beyond just the tv's failing, do lights flicker or get dim then bright in your house. The neutral leg of your house wiring could be loose or corroded causing power surges specifcally to your house. May I also suggest, if you've never heard of a tv 's name before you see it in a store, don't buy it. Buy a respected name that you have actually heard of before.
  • Joe LeBlond
    Good luck deborah! If you know the electrician who rewired, could you inquire with him/her to have them check the neutral leg of the incoming line. TV's are especially susceptable to current surges. To have so many fail at once is certaily worth looking into. I'd be worried about an electrical fire if the problem continues. Hope i've been of some help.
Code needed
code normally 1234 or 0000
cheers davetech
What's your problem?alba lcd32947hd won't turn on from standby mode
My tv just over a year old Alba LCD32947HD - PSU - 17PW25-4 - 250111 V1 - 23012666 gets no power on and not even a light in front after I plug to the mains. Checked and power goes to the psu , main Av and the Inverter. Can somebody help? Could that be the remote control. Please help. Thank you in advance. Harry.
Poor picture quality on alba LCD TV after recent digital switchover.
Digital TV uses less airspace than analogue TV, so after the digital switchover there'll also be more room for services such as high-speed mobile broadband and high-definition television (HD TV).
My alba tv which is two years old is flickering non stop on every channel and even on the menu
Check the power outlet. Try connecting it to a different power outlet. Look for any jammed buttons on the remote. If the problem persists, this might need attention by a qualified service technician.
2helpful
Alba 16inch tv and dvd combi has turned black and white how can i change it back to coulor
Make sure the source is on TV
Press "menu"
quickly type "4725"
select "diagnostic"
choose "factory reset"
If this doesnt get colour back then its broken
6helpful
3answers
Alba 42"lcd tv watching tv it just went off,
Alba is now a product of Argos, their low cost help line number is 08456040105
Alba DVD recorder won't recognise any discs
The Alba DVD recorder may not recognise any disc due to one or two of the following reason.
1, the optical pick up (lence) may be dirty or may have gone bad.
2, the cable which connects the optical pick up to the circult panel board may have go borken.
Broken Screen
Ebay is your best bet,check in the faulty section.
Broken Screen
Man I feel for you..
You can have them repaired using a TV Repair guy but often it costs as much as a brand new tv. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
5helpful
3answers
Alba tv plays xbox 360 games in black and white
This is an easy fix.
Within the xbox, goto system settings, and chnage the display output ot pal 50.
Problem solved!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
