20 Most Recent
Alba LDVD1538WDCH LCD TV Questions & Answers
My tv is on stand by but i cannot get it to go on
Try a hard reset to it. If it not help you, the main power supply board is faulty. Replace it. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
7/30/2015 12:16:57 PM •
Alba...
Answered
on Jul 30, 2015
Usb is not showing up on source
some tvs require a drive that has its own stand alone power source, & a compatible file system, not all will accept NTFS, Fat32 will only hold files under 4gb try EXFat, or check your manual for what usb devices it accepts, most older tvs wont accept a stick, need external hdd with power.
5/9/2015 9:06:41 PM •
Alba...
Answered
on May 09, 2015
My alba 19inch tv is giving me problems. when I first switch it on you can see the picture and you can hear the sound. After a few seconds the picture disappears and you can only hear the sound.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
5/1/2015 5:31:12 AM •
Alba...
Answered
on May 01, 2015
Tv stuck on scan
Try Re-set... Turn the TV off. Un-plug it.
Every Tv made in the last 10 years has a Re-set...
Look up on the Net.. How to Re-set your TV...
Keep in mind. If you re-set it. It will go back to how you first got it.....
Hope this helps....
4/7/2015 1:17:45 PM •
Alba...
Answered
on Apr 07, 2015
WHERE CAN I GET A REMOTCONROL FOR IT
I bought a RCA universal remote for about $15 very nice, better than the factory. The instructions are excellent. There is a code that needs to be entered for your specific unit on a list with the instructions.
3/28/2015 12:32:59 PM •
Alba...
Answered
on Mar 28, 2015
I can't turn up the brightness on my TV
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
3/7/2015 10:50:31 AM •
Alba...
Answered
on Mar 07, 2015
