Try to check first battery terminal it may have loose contact which do not have supply to the circuit.just also considered the battery check if it is need new replacement. now after you check battery terminal and as well as the battery test it with in your tv unit if it is now working. if still doesn't work you can check your remote control through digital camera. turn on your digital camera set to camera mode now point the remote control to the digital camera and press any button look at the screen of the camera if their is a light which means your remote now is good. the problem is with in your tv IR sensor either defective or no supply.good luck thanks.
