SOURCE: HP Solution Center
When you click on the icon it is trying to open an xml file which is like a web page. The parsing error means there is an error in the page. I think the best way to cure this problem is to go to http://www.hp.com/#Support and put in the model number of your computer and download new drivers for your printer. You should also uninstall any current drivers you have from control panel's add and remove programs.
SOURCE: When I try to open the HP Solution Center I get
This message is because Microsoft XML services
are having a problem.Here is what you
could do to fix.
Step 1: Uninstall
All-in-One software
Step 2: Restart the
computer
Step 3: Install the Windows installer 3.0
http://www.microsoft.com/downloads/details.aspx?FamilyID=3144b72b-b4f2-46da-b4b6-c5d7485f2b42&displa...
Step
4: Download and install MSXML
Step
5: Reinstall All-in-One software
Hope this helps
SOURCE: From the HP Solution Center
1) Go to C:\program files\HP\digital imaging\bin\ and check how many folders are there for HPQSCLOC .If there are only one folder for HPQSCLOC in that case don't touch the folder. 2) Go to command prompt TYPE THERE "CD..." AND HIT ENTER KEEP TYPING "CD." AND HIT ENTER UNTIL WE SEE C:\ WHEN C:\ COMES TYPE THERE- "regsvr32 /u hpqscloc.dll" We may get an error in vista which says module failed to load Follow Step 3 3) Open cmd prompt Go to C:\ Type there "regsvr32 hpqscloc.dll on" 4) Download and install http://www.microsoft.com/downloads/details.aspx?FamilyID =32BC1BEE-A3F9-4C13-9C99-220B62A191EE&displaylang=en Download and install http://www.microsoft.com/downloads/details.aspx?familyid =A5C84275-3B97-4AB7-A40D-3802B2AF5FC2&displaylang=en Try to scan Or else follow step 5 5) Uninstall the imaging device and the solution centre 6) Download msicuu2 from microsoft.com http://www.filewatcher.com/m/msicuu2.exe.189920.0.0.html Run the windows cleanup utility Delete AIO Scan from it 7) GO TO CMD PROMT Then type CD programfiles\hp\digital imaging\bin 8) Type regsvr32 /u hpqscloc.dll try scanning and check if it works or not if not follow another step 9) Tried to uninstall the software 10) then install the software back It will scan fine
WHEN C:\ COMES
Follow Step 3
3) Open cmd prompt
Go to C:\
Type there
Try to scan
7) GO TO CMD PROMT
It will scan fine
If you need more help come back.Post /
thumbs / testimonial are
welcome!
