20 Most Recent HP DesignJet 330 InkJet Printer Questions & Answers
unfortunatly the only fix is to replace the firmware chip itself which requires a new main PCA/formatter, I would suggest with the age of this unit that would be most difficult to get hold of and would probably cost more to repair than it would be to procure a 2nd hand more recent unit
HP DesignJet 330... | Answered on Jan 31, 2014
A clog print head noozle sometimes the cause of this problem, so try to clean it and try plug again
HP DesignJet 330... | Answered on Jan 12, 2011
Probably a bad trailing cable. I've seen it many times.
HP DesignJet 330... | Answered on Apr 26, 2010
Guys
1. Thanks for coming up for air
2. We figured out the problem
3. It's a master panel board in the bottom right corner of the printer
4. At this time we will be throwing out this HP 330 and getting another
Thanks for your help.
HP DesignJet 330... | Answered on Oct 04, 2009
This indicates that either the black print cartridge is faulty, misplaced or missing. Try inserting a different black cartridge. Also firmly press the large green plunger fully down once, and then release it. The plunger should return to its original position. Then reset the printer and try printing again. If the problem persists try using a new black cartridge and primeit before use with the power on.
HP DesignJet 330... | Answered on Sep 24, 2009
Sounds like a partial power supply failure; the output for the motor drive(s) has failed. This may be a separate assembly but some covers may need to be removed to determine this.
HP DesignJet 330... | Answered on Mar 17, 2009
The same Ram can be found in old desktop computers, 486 is about the right time for a 16mb or 32mb RAM chip.
HP DesignJet 330... | Answered on Jan 14, 2009
played with the set up procedure and it fixed itself. thx for the followup
HP DesignJet 330... | Answered on Sep 09, 2008
see the driver are properly installed or if you can do litte bit of serviceing like add oil on the rod . bye
HP DesignJet 330... | Answered on Sep 28, 2007
To solve issues visit https://support.hp.com/in-en/document/c04530811 to get quick support call our Toll-Free 1 888 224 4280
HP DesignJet... | Answered on Jul 30, 2018
HP DesignJet 330 InkJet Printer Logo
Popular Tags
12 questions posted
Clive
Clive
View Most Popular
DesignJet HP
  • DesignJet HP
Most Popular Question
film error lights flash replaced ink
  • Office Equipment & Supplies
