Posted on Jun 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is one ( 1 ) printable item cancelled but cannot be removed, so my printer doesn't print. " it says 1 document in queue. what shall I do ? thanks
Carlo Barzo
Level 3:
  • Master 530 Answers
  • Posted on Jun 09, 2011
Carlo Barzo
Master
Level 3:
Answers
530
Questions
0
Helped
128419
Points
1767
Turn off your computer for about 2 minutes same with your printer. Then turn on your computer first and if you are already on your desktop turn on your printer. Then go control panel and click your printer and delete the queue document. Have a nice day!
HP Photosmart Plus 209a-m doc in queue won't delete
using windows explorer, go into windows/system/spool/printers and erase contents in last item
3answers
Print queue stops document and will not resume
Clearing the Print Queue in Windows:
Open the Print Queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double-click to open the appropriate printer's queue. The Print dialog box will open. Here you will see a list of all of the jobs waiting to print, along with the status of each job. The first print job is at the top of the list.
To cancel a document in the list, right-click it and select Cancel Printing. Most often, it is better to cancel all of the jobs and then resend the documents to the printer.
Cancel All Documents
  • Windows 98 - click Printer on the menu, select “Purge Print Documents”
  • Windows XP - click Printer on the menu, select “Cancel All Documents”
  • Windows Vista - click Printer on the menu, select “Cancel All Documents”
Please note that you must have Administrative rights in Windows XP and Vista to cancel print jobs. If you are the only user, you automatically have administrative rights. If you are on a multi-user computer, you must be an administrator. If are on a network and get a message saying that you do not have Administrative rights, find someone who does.
Under normal circumstances, printing documents are cancelled and will disappear from the queue. If one or more do not disappear, shutdown the computer and restart. When shutting down, you may get a message warning you that your print jobs will be lost if you continue. Tell Windows to shutdown anyway. When you restart, Windows may tell you that you have print jobs waiting. Tell Windows to delete them.
Before you resume work, open the Print Queue from the Start menu. You should find the queue empty. If you are using Windows XP or Windows Vista and the queue is not empty, you will be unable to print. Before trashing your computer, you can try to clear the queue using a secret Windows command.
Click Start, Run, and type “Net Stop Spooler” (without the quotes). Then press Enter. Shutdown the computer and restart. The print jobs should be removed. If they are not, shut down the computer again, take a deep breath, and then go for a long walk. The queue should be clear when you return. Note that you must restart the computer for your printers to resume normal operation.
Goodluck,
Please don't forget to rate the solution.
I have a document stuck in the print queue, which won't cancel or restart, help!
Turn off printer for 2 minutes @ least, turn back on, or delete printer and re-install printer. Go to HPsupport website enter your printer model info update drivers.
Pimxa mx340 document won't stop spooling
try removing the power cord to the printer buy turning off the power point to try and clear the printer's memory .
When the message "5 documents pending" appears but
Rebooting the computer may help get rid of the print jobs stuck in the queue. If not, follow these instructions carefully:
For Windows
Stop the Print Spooler
  1. Go to Control Panel
  2. Go to Administrative Tools
  3. Go to Services
  4. Look for Print Spooler in the items. Double-click on Print Spooler -> click on Stop -> click Ok. Set the Services window aside.
Clear the Spool folder
  1. Go to Start
  2. Type Spool in the Search/Run bar, hit Enter.
  3. Open PRINTERS folder
  4. Delete all the files in the PRINTERS folder. Close the Window
Re-enable the Print Spooler
  1. Go back to the Services window
  2. Double-click on Print Spooler, and click on the Start -> Click on Ok. Close the Services window.
Go to Printers and Faxes and refresh the page. It should clear the print queue now.
For Macintosh
Simply launch Terminal and type cancel -a - That will clear the print queue.
1helpful
3answers
It takes unduly long time to cancel a print-command on any printer, when we work on Windows. What is the surest way to kill a printing command.
Open "Printers and Faxes" from the Start Menu. Open the print queue for your printer by double-clicking on your printer's icon. There will be a list of all the current print jobs. There you can right-click on a job and select Cancel, Restart, etc. Cancel will remove it from the list.
If you are not on the computer that is connected to the printer, you might not have permission to change the queue. Then you should go to the computer that is actually connected, and use this procedure there.
1helpful
I can't delete a document in the queue for
remove usb cable from the printer then try to cancel it then after switch off your printer then after trying to cancel if problem occurs then u have remover your printer driver and reinstall it
My new printer suddenly stopped making a connection between the printer and the item to be printed.  Printer says "Printer Ready" but does not show the item to be printed in the queue.  Cedar
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
I want to print new page of printing printer keeps churning out prvious printing instrctions i am 78yrs old still learning
What you need to do is clear out the printing "QUEUE".
The printer is one of the slowest devices in a computer system. If you had to wait for it to print your document before you could resume writing, you would quickly go back to using a typewriter. To eliminate the delay, Windows reserves a portion of memory for something called a “print queue” (or spooler). The queue works on a first-in first-out basis. You can continue to use the computer and send jobs to the spooler as it feeds a steady stream of data to the printer.
Print queues are nice, except when something happens in the printer to cause it to stop functioning. Sometimes it is just a paper jam and sometimes it is a bit more serious. If you need to cancel the jobs in the print queue, you can simply double-click the printer icon (in the system tray down by the clock) and open the print queue. Depending upon the length of your document and how many documents are waiting to print, the printer icon may appear briefly or for a sustained period. (Note: This would be a good time to remove the paper from the printer before continuing.) If the icon is not there, you can manually open the queue.
This should solve your problem, Let me know how it works for you..
~~Jastababe~~
k24674
ADMIN Andrew
ADMIN Andrew
