SOURCE: 220 watt car amp -- 8 or 10 gauge amp kit?
when in doubt go bigger, you might want to get a bigger amp down the road, so its better to not have to buy another wiring kit later.
and the bigger the wire the less line loss you will have so your amp will sound and perform better.
SOURCE: Its stuck on protected. I recieved the amp for my
whats the ohm rating of amp probally 4 what is the ohm rating for sub how many subs are you running how do you have them hooked up parallel or series is your wiring to amp right
SOURCE: i am looking to buy a 1200 watt jensen 2 channel
I would recommend you purchase a brand name 600watt RMS amp instead of a Jensen 1200 watt peak amp. Trust me you will notice the difference. Try a kicker, hifonics, MTX, audiobahn Autotech... Its not the watts its the quality of the watts..
SOURCE: i have a 650 watt lanzar vector amp hooked up to 2
the problem is that you must have your subs wired to a lower impedance than the amp can handle. Wire your subs to 4 ohms, or get an amp that can handle 2 or even 1 ohms and crank it and enjoy!!!!!!!!!!!
