20 Most Recent Jensen Iso-Max Stereo Line Output Isolator 1 to 1 Ratio Car Audio Amplifier Questions & Answers
Common fault but as others have suggested, check aerial plug. It does fall out, speed humps vibration,cause it to come out of it's socket.If not this, try a seperate aerial such as a piece of wire or a small screw driver blade in the hole. Press search and see if radio finds a station and locks on.If it does then you know you have an aerial problem and your radio unit is ok. Sadly, if no luck and no result then the only answer is to relpace the unit as it is not servicable.These can be found at some car breakers but take your car and make sure that you buy a tried and tested unit with its pin No. Typical costs are £30 with casette and £70 for cd player.
However because there are so many different types of socket and plug arrangments on these units and they all look alike , don't be tempted to part with any cash until you have got the correct one that fits your car and it works. If does and you have its pin, it will have to be entered to make it work and you have made a written note of it in your Ford hand book , then pay the man. Good luck From been there and have the tee shirt. J.R. Note. Halfords do a fitted alternative replacement for around £150 if no luck and you are prepared to spend that kund of money.
Jensen Iso-Max... | Answered on Mar 23, 2009
i searched and found the diagram for you hope it helps.
Jensen Car Audio... | Answered on May 07, 2019
Place your question or part of it in YouTube. I'm sure there's a similar problem with a similar model.
Jensen Car Audio... | Answered on Mar 31, 2019
This is a loose connection. Can you get the unit out? All of the connections except power (fairly sure about that) must be checked. Optional - if you can't remove the unit then you'll have to go to a professional. Put Jenson vx 4024 and your question in Youtube as well.
The writing was on the wall (pardon the pun) in 2008 when our founder designed and released the first In-Wall speaker. 5 Ranges and 9 years later, In-Wall and In-Ceiling Speakers have evolved and morphed into Hi-Powered In-Wall systems with Glass fronts never seen anywhere in the world before. Beauty and Grunt! Front speakers (some with inbuilt Centre Speakers) have been designed mainly for high powered Hi Fi and Stereo application providing clean, accurate balanced performance with deep, strong Bass.
You need of any our Technical Support agent. Please call Technical Support team at +44 203 880 7918 our experts are available 24/7 by phone.
https://www.customersupportcare.com/dell-printer-support.html
Jensen Car Audio... | Answered on Mar 28, 2019
First of all, why is this diode broken? Were you using the unit when it broke and/or burned? More information please.
If you’ve found this helpful, please click the green “helpful” icon. If you have 20 seconds please leave a few words as a review or recommendation! Also, follow me for more answers to everyday issues, I’m all for saving you money and making the most of your time! Thanks and have a great day!
Jensen Car Audio... | Answered on Mar 15, 2019
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 yearsmust try this bitman and reliable-store. Both are good
Jensen Car Audio... | Answered on Feb 06, 2019
I would purchase a standard loom from a car radio shop or an adapter for your vehicle.
Jensen Car Audio... | Answered on Jan 22, 2019
Does it have a removable control head? If so, be sure that it is correctly seated and snapped into place. Also be sure that all plugs are securely seated like power, clock, speaker and antenna plugs. Good luck
Jensen Car Audio... | Answered on Jan 03, 2019
You can buy an antenna multi plug adapter kit. Cheap. You can use it to plug into.
Jensen Car Audio... | Answered on Dec 26, 2018
Car Audio & Video Logo
7 questions posted
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Car Audio & Video
Most Popular Question
loss reception in 2002 ford focus
  • Car Audio & Video
