Have you tried going to Dell and downloading the drivers for it? I had an A920 until a couple of weeks ago so know that every once in awhile, for no reason, it quits working. Mine would print but not scan! I went to Dell, downloaded updated drivers and this seemed to fix the problem. I had to do the scanning through the program, not by pushing the buttons, tho.
A quick fix for most communication errors can be achieved by
resetting the printer and/or rebooting the PC. Simply disconnect the printer
from your computer (if USB connected)> reboot your pc > unplug and
re-plug the printer into the power source to reset it. When the printer turns
on, reconnect it to your computer (if USB connected). Then try to print again
once the computer fully recognizes the USB connection or when the WiFi light on
the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/guXLhl. Select your operating system, download and execute the file.
achieved by resetting the printer and/or rebooting the PC. Simply disconnect
the printer from your computer. Reboot your pc. Unplug and re-plug the printer
into the power source to reset it. When the printer turns on, reconnect it to
your computer. Then try to print again once the computer fully recognizes the
USB connection.
1. Disconnect the printer from your computer.
2. Re-brick your printer.
Pull out the power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers
and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB
connection. To check, go to Control Panel > Printers and Faxes. If you see a
new Lexmark print object in the list, then try to scan a document again to
verify that the problem is fixed.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolve your problem, your rating will be greatly appreciated. Thanks.
USB connection.
and Faxes.
4. Reboot your pc.
new Lexmark print object in the list, then try to print a document again to
visiting the Lexmark website at http://bit.ly/lgJCxt. Select your operating system, download and
execute the file.
Try to scan again to verify that the problem is fixed.
If the problem continues, please contact Lexmark Technical Support for additional assistance.
1. Reconnect the PC and printer, replace any faulty
cables. If using a parallel cable, check that the parallel
port is properly configured in the BIOS.
2. If printing is OK check that the Scan driver is also
installed
