20 Most Recent Lexmark S305 IMPACT LEXS All-In-One InkJet Printer Questions & Answers
You should be able to download all the files you need from Lexmarks website.
Lexmark S305... | Answered on Oct 11, 2014
Make sure there are no print jobs stuck in the queue. If you're using Windows, go to the Control Panel > Printers > double-click on the Lexmark print object. Delete all print jobs pending. If you can't clear all print jobs, follow the steps below:
1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in "NET START SPOOLER" (this will restart the print spooler service)
Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Reboot your computer. Then, try to scan again.
Lexmark S305... | Answered on Oct 08, 2014
After you changed the printhead, even full cartridges need some time to fill up the head. So just copy a newspaper, put in a normal sheet of paper, and tell the printer it is a Photo, with Photo paper. It then will press the most ink.
If one of the colours start, it could take a complete A4 photo, before all colours are coming through.
I assume you did install the new head correct and not something else was defect before you started to change the head anyway. Because when something else was defect in the first place, a new head won't change that.
Lexmark S305... | Answered on Sep 12, 2014
firstly printing through a network need to ensure you have internet access weather home or form the office.second having correct printer driver is very important. uninstall old drivers check devices manager for installation and devices details. if the problem persist check your USB printer cable the following link should be of help. http://www.lexmark.com/publications/pdfs/2007/2009-fall/v9842009_en.pdf
Lexmark S305... | Answered on May 15, 2014
Check and see is the printer sitting over a heat source like home heater / water heater or electric heater.
External heat will dry up ink.
Try to relocate printer and computer to a cooler spot.
Lexmark S305... | Answered on Jan 18, 2014
Please follow the steps below on how to print using black ink only on your Lexmark S305 printer:
For Windows:
  1. With your document/file open, click File.
  2. Click Print.
  3. Click Printing Preferences/ Properties.
  4. In the Lexmark S300 Series Printing Preferences window, select print using black ink only.
  5. Click OK to save the settings.
  6. Click Ok again to print your file.
For Mac operating system:
  2. Click Print.
  3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media in a drop down box and select print in black and white.
If you wish to set this as your default print setting, please follow steps below:
For Windows:
  1. Go to Control Panel.
  2. Open Printers and Faxes.
  3. Right-click on Lexmark S300 Series print object and click on Properties.
  4. In the Lexmark S300 Series Properties window, go to Advanced tab. Click on Printing Defaults.
  5. Under Ink Use, select Print using black ink only. Click OK.
  6. Click OK button in the Lexmark S300 Series Properties window to save the changes.
Your printer will print in black only the next time you send a print job to the printer.
For Mac:
  1. With the file (you wish to print) open, click File.
  2. Click Print.
  4. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Note: The 100 standard cartridges yield around 175 ISO Pages. You can also save on ink and stretch your ink investment if you use only 100XL high yield cartridges. These contain almost 3x as much ink as a standard cartridge for a small increment in price.
Lexmark S305... | Answered on Jan 15, 2014
clean the service station
Lexmark S305... | Answered on Dec 14, 2013
Try using the Lexmark Printer Home when scanning. If you have a PC, to access it click on Start > All Programs > Lexmark > Printer Home. You can scan to a .jpeg, PDF or .doc.
If you're scanning from the control panel of your printer and you're getting an error message, "Cannot Retrieve Application List", most probably your firewall is blocking your printer from downloading the applications. You might want to add the Lexmark files in the exception of your firewall. Click on the link on how to add exceptions to your firewall.
If you're trying to scan to email (email client), try to check this link: http://bit.ly/k0w0Hp
Lexmark S305... | Answered on Feb 08, 2013
Make sure that you're using genuine Lexmark cartridges. If you are, try the steps below:
- Update the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
- Perform a maintenance on the cartridges. To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
If you still have the same problem after performing those steps, it could be a problem with the printhead. You might want to contact Lexmark's technical support.
Lexmark S305... | Answered on Feb 01, 2013
Lexmark S305 IMPACT  LEXS All-In-One InkJet Printer Logo
Popular Tags
126 questions posted
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Lexmark Office Equipment & Supplies
Most Popular Question
printhead message
  • Office Equipment & Supplies
