SOURCE: missing my scx-4100 printer driver
http://www.samsung.com/us/support/download/supportDown.do?model_nm=SCX-4100&mType=DR&vType=L
Above is the URL for your specific Driver. You may have to copy and paste it into your address window.
SOURCE: problem scanning with samsung scx 4521f
My connection is via a parallel to parallel cable, and I am also having a similar problem. I'm reading that usb to usb cable is the only way it will properly function. good luck with it!
SOURCE: SCX 4100 scanner problems
In the SmartThru application, find the devices connected list (usually on the upper right corner at the main screen). Select the SCX-4100 from the list, since this software will work with many scanners. After selecting the unit, close and restart the program.
Be blessed.
SOURCE: network scanning problem
scanning from any device is simple you need three things
user name bill
password piguine
path \\server\scans\shared folder
the scanner needs rights to write to a folder on the network.. good luck
