Question about Samsung Office Equipment & Supplies
Network scanning problem
We have Samsung SCX-5x30 Series PCL 6 installed on our network of 3 pc's. we use Smarthru 4 to print, copy, and scan. print and copy functions work from all pc's. scan works perfectly from only 1 pc but not at all from the other two.
  • Anonymous May 01, 2009
    thank you! your tip on resetting the path did the trick. :)
Anonymous
    New Friend:
  • 63 Answers
Scanning from any device is simple you need three things
   user name   bill    password    piguine    path            \\server\scans\shared folder
the scanner needs rights to write to  a folder on the network..  good luck
Posted on May 01, 2009
How can i get scan drivers for a samsung clx-6250fx?
You can find the drivers in the website of Samsung. If it's already installed but not working properly then update it. You can use RadarSync to scan your computer so that you will find the available update.
David
Jun 24, 2013 | Samsung SCX-6x45 Series PCL 6
Tip
Samsung SCX-4500W restore wireless printing on cryptic error
For those having trouble wirelessly printing to their Samsung SCX-4500W printer from a Windows computer, I have this "easy" 13-step process that usually fixes my most common printing problem:
The symptom:
You haven't used your printer in a couple of days and have just hit the print button in an application you wish to print a document from. Instead of your printed document gracefully emerging from your printer, a Samsung status window appears on your computer above the task tray, cryptically announcing "The current printer port is not supported for the current printer status". You scratch your head in complete confusion.
The solution:
  1. Go into the room where your printer is. Observe that it has dropped its wifi connection and not reconnected automatically - the blue light indicating wifi is no longer illuminated.
  2. Turn off the printer, wait a few seconds, and turn it back on.
  3. Rebooting always causes a blank page to be ejected - how annoying! Open up the tray and reinsert the blank sheet.
  4. Wait for the blue wifi light to come on.
  5. Return to your computer and open the printer job queue window. Locate your document in this window with "Error" status next to it: right-click on it and select restart so its status changes to "Printing".
  6. After a while, notice the status has changed to "Error - Printing" or "Error - Sent to printer". Since restarting the job was not successful, right-click and select cancel. Press the OK button in the confirmation dialog. You may have to do this a second time before the job clears.
  7. Return to the application you printed from and re-print the document.
  8. Double-click on the blue Samsung "S" icon in the task tray. A window titled Samsung SX-4500W Series will appear in the lower right. Observe the status first says "Please wait..." then show the same cryptic message "The current printer port is not supported for the printer status". Grrrr.
  9. Check if your computer really can access the printer by opening web browser and typing its ip address. For me, it is 192.168.1.70. Alternatively, click the "Printer Setting" button in the window of step 8. Observe that the printer reports it is alive and ready for action. This is good.
  10. Check if any other Samsung software is able to use the printer: Open SmarThru 4 software, select "Scan To", "Folder", then hit "Scan" button. Observe that scanning from the printer works absolutely fine. Close SmarThru. So the problem is just the crappy printer driver.
  11. Close any Samsung windows you have open. Navigate the start menu to Samsung SCX-4500W Series->Maintenance. The installer will run in maintenance mode and find your printer on the network (and show its ip address), as well as an option to use it on "Local Port". Select the printer on network and click Next. Select "Samsung SCX-4500W Series printer driver" to repair and hit Next. The driver will re-install. Click Finish when done.
  12. Return to your application you wish to print from and activate the printing of the document again.
  13. The Samsung status window will once again appear in the lower right proclaiming "The current printer port is not supported for the printer status". Ignore this stupid message and close the window. Go to the room with your printer and with any luck, you will find your printed document waiting for you!
Once you are well practiced at this, and can fully appreciate how useless Samsung's software developers are, you can just do steps 1,2,3,4, 5, 6,11,12, and 13.
on Mar 09, 2011 | Samsung SCX-4500W WiFi Multifunctional +...
My printer is Samsung SCX-4100.. The software SmarThru is not compatible for Windows7.. Do you have any software compatable so i can perform scanning..
for scanning you can use every program that supports scanning (irfanview is freeware, ABBY finereader and many others). You can try new version of smarthru (for samsung SCX 4300).
pifonski
Feb 25, 2011 | Samsung SCX 4200 All-In-One Laser Printer
How to scan into my computer
Hello, I am happy to help you with your question. Samsung SCX-4200 supplies software calls Samsung Smarthru. This software application includes a scan command. The software is locagted on the CD that accompanied the printer.
Here are some excerpts from the manual:
Your machine offers the following ways to scan an image:
• From TWAIN-compliant software: You can use other
software including Adobe Photoshop Deluxe and Adobe
Photoshop.
• From the Windows images Acquisition (WIA) driver: Your
machine supports the WIA driver for scanning images.
• From the Samsung SmarThru software: Launch Samsung
SmarThru and open Scan To to begin scanning.
NOTE: To scan with your machine, you must install the
software.
Loading document
You can use the document glass to load an original document
for copying and scanning.
1 Lift and open the document cover.
2 Place the document face down on the document glass
and align it with the registration guide at the top left
corner of the glass.
3 Close the document cover. Be careful not to move the
document.
NOTES:
• Leaving the document cover open while copying may affect
copy quality and toner consumption.
So, basically, if you have the software installed. Open the Smarthru software, load your original onto the glass, face down, and close the lid. Select scan, the software may provide you with a preview of the scanned image. Once you scan the document, you must save it to a location on your hard drive, often it is called "My Scans" in your "my documents" file.
I hope that this is helpful. I have attached a link directly to the Samsung website manual for your model
http://downloadcenter.samsung.com/content/UM/200912/20091211171126218/Guide_EN.pdf
Dec 22, 2010 | Samsung SCX 4200 All-In-One Laser Printer
How do I turn on the scan function on the Samsung SCX-4300?
Good Day Sir, Your machine offers the following ways to scan an image.
  • From TWAIN-compliant software: you can use other software including Adobe Photoshop.
  • From the Windows images Acquisition (WIA) driver: Your machine supports the WIA driver for scanning images.
  • From the Samsung Smarthru software: launch Samsung Smarthru and open Scan to begin scanning.
Have a nice day!
Apr 06, 2010 | Samsung SCX-4300 Monochrome Laser...
Samsung scx-4200 does not give me the option to scan to pdf file
I used a program called SmarThru 4 with the same printer-scanner. Works. Give it a try :).
Jun 29, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Cannot get scanner to work.
Your best bet is to install the software then open Smarthru software and scan from PC
Mar 06, 2009 | Samsung SCX-4725FN All-In-One Laser...
Samsung scx-420f series pcl 6 reads scanner locked.
You can solve this problem by entering TECH menu and then --> Data setup --> Clear all mem. And ypu will be ok :)
Jan 07, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Samsung scx-4100 scanner error - cannot detect device "Samsung.."
I just fixed this problem for my computer. Try installing the scanner driver. You probably have the printer driver installed but the scanner driver is needed for Smarthru
http://www.samsung.com/us/support/download/supportDown.do?group=&type=&subtype=&model_nm=SCX-4100&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010300&disp_nm=SCX-4100&model_cd=&menu=download
Jan 05, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Fax device I/O error
installed samsung scx-4521f multi function printer. can't fax from smarThru program. get message : Fax device I/O error
Jan 11, 2008 | Samsung CLX 3160fn All-In-One Printer
704 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
