D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
Anonymous Posted on Mar 09, 2011
I cant log i i changed name / pwd and forget it. i had it unplugged for a year but still cant log ijn how can i reset pasword or retrieve log in info?
Anonymous
Level 3:
Genius:
  • Master 1,189 Answers
  • Posted on Mar 09, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1189
Questions
0
Helped
360919
Points
3265
Hi murple_1, these instructions, will help you "reset your password!"
Part 1
To Reset: "Password"
Do the following:
  1. Turn-on the D-Link to start the "Set-up Screen"
  2. Type: [Ip Address] in the "Web Browser Address Bar"
  3. Check the User's Manual / Guide for [Address] ie: 192.168.../...
  4. Next, use the {Default} User Name: ie. "administrator" in lowercase to Log-in!
  5. In the (Password) box: Leave it "Blank! = "No Password"
  6. Next, click on the "Wizard" button; to run the configurations."
  7. There will be "Options" to "Change the Password!"
  8. Now reset the Time-zone.
  9. Next, "Reset the Internet Connections."
  10. "Follow all the instructions afterward!"
  11. To finish: "Restart the D-link."
Part 2
Hold - [Down] "Reset Button, in the back of the D-Link for 15 - 45 seconds"
"This will {Reset the D-Link to Factory Settings}."
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
  • Anonymous Mar 18, 2011
    This 'comment' is for FixYa! So my understanding is; -10 is {subtracted} for "Not Helpful: Solutions!" But! When the "Solution is Very Helpful! = 5 or < LESS!" ? Is this "Correct"!? I have another ?Question? Do a number between a (100 to 1000) people respond quicker, and more to "Solution that do not help!" In comparison to the "Solutons that do?"
Anonymous
Level 2:
  • Expert 104 Answers
Anonymous
Expert
Level 2:
Answers
104
Questions
0
Helped
53153
Points
355
You will need to do a factory reset on the router by holding the "reset" button on the back while the router is plugged in for 5-10 seconds (the LEDs will indicate that the router is restarting).
After you've reset the router to factory defaults you can log into it by opening a web browser, going to http://192.168.0.1, and using a password of "admin" (there is no username).
Hope this helps
Please rate this solution, thanks!
Anonymous
Level 2:
Sergeant:
  • Expert 173 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
173
Questions
0
Helped
54138
Points
568
Hey there,
You can reset your router back to factory default.
Look at the back of the router:
http://images.dlink.com/new/products/WBR-1310/WBR-1310_back.png
There's a very small button on the right hand side labeled "reset".
While the router is plugged in, use the end of a paperclip or ballpoint pen and push in this button, holding it pushed in for 10 seconds.
Let go and then let your router reset and start up again, this usually takes about 3 minutes.
It should now be set back to it's default settings.
Hope this helps!
Anonymous
Level 3:
  • Master 1,768 Answers
Anonymous
Master
Level 3:
Answers
1768
Questions
0
Helped
528701
Points
5915
Please provide more information as to you issue such as :
a. model number
b. year manufactured/firmware updated
c.Are you using router wirelessly or hard connected.
d. You have checked the user manual 1st.
e. You have confirmed that you have connectivity with the ISP ( internet service provider)
f. uninstall/ reinstall the router software with the CD provided from the manufacturer.
Forget pattern to unlock samsung gts5300 and forget password and gmail pls help
Can you prove that you own the phone? It could be a stolen or a lost phone. Change the SIM, reset the phone and start all over again.
Reset pasword canon IR C2550
Clear Admin Password Get Full Access
You need to get access to service mode settings which a printer technician should know then follow below instructions
>COPIER>FUNCTION>CLEAR>PWD-CLR
Headlight PWD-CLR and hit OK
I have lost the password to my lynskys /wrt54/g router, how can I retrieve it or change it?
Try http://www.linksys.com/connect and if unsuccessful, there is no way to 'retrieve' a router password. If you forget it, you will have to factory reset it
Open a web browser and enter the address "http://192.168.1.1" in the address bar.
Leave the user name blank and enter the password "admin" without quotes. This is the factory default password
I cant remember my pasword
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor pissword you can change or remove your pissword from there
also
click start control panel user accounts
on the users tab,click the name of the computer administrator you can change the password there
hope this helps
2helpful
Someone logged in my mxit and change my log in name and pasword. how can i get it back plz. my nr. is 0848127797. reply on 0848127797
Sm1 log in wit ma acount bt when i try 2 use it it tels me tht ma pin its invalid plz help me plz ma mxit name its kinetic deep ma mxit id its 0799045605 plz reset ma pin n gv me new 1 ma number its 0843298958 tnx alot
2helpful
I have changed my gmail pasword few days back ..Once i came to open my gmail account I forget my password .. I have also forget my secondary mail password.. one Thing I can assure If given 5 Paswords out...
Hi, Bad news is that if you had forgotten the password for secondary E-mail also and unable to retrieve password from forgot password option on Gmail, then there is no way you can log in to your E-mails now. No 5 options kind of thing is there. Only option is create a new account on G mail now.
Canon IR 3100 CN needs pasword
you need to clear thepassword in this order touch ADD FUNC key then the 2 and 8 keys together then touch ADD FUNC key again lcd screen should change touch copier then function then clear then pwd then ok then yellow reset 3 times that should do it
3helpful
4answers
I cant acces my yahoo mail account and cant change password
to change it, you may have to ask a few questions on help desk to retrieve it.or you could cancel the account and set a new one up. you should be able to change your account pasword through customer service then create a new one using the old email address. use a good virus sweeper ie avast or spy hunter to run a check on your system DO NOT use the XP doctor that comes up when you use the internet that itself is a trogen. and i would not recomend any norton programms thy can upset your system big time.
Aug 16, 2009 • Yahoo Mail
11helpful
4answers
Pls give me afaq shamel 014 modem settings
I CANT CHANGE NEW USER NAME AND PASSWORD
2answers
I cant rememger my facebook password
Facebook sends your request to the email address you used to register.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
