Would suspect you have a bad lid switch, may instead have a problem with the neutral drain of the transmission, but suspect you only need to replace the lid switch. The control panel is secured at the end caps, usually screw in back, or putty knife in base to release, control panel rotates up, remove whole cabinet if necessary, all front serviceable,(if it stops in the same spot it is in the timer though)
hope this helps
