Troubleshooting & Support
Hot Topics:
- lid switch
- manual
- belt
- spin
- water leak
- agitator
- Parts list
- 3357978
- remove cabinet
- lint filter
- clean fabric...
- open
- makes noise...
- leaking water
- coupling
- sm8280867
- water fills...
- lid switch test
- cycle speed
- diagram
- replace lid...
- Burning smell
- hot water
- 3951702e
- american...
- timer
- clutch...
- reset button
- clutch
- parts diagram
- View All »
Problems & Solutions
won't start
sounds like you have a bad motor,when it heats up it stops running and when it cools down it will run again but one of these times it...
where can i buy a whirlpool ultimate ii lid...
Please check for spares from the following link:www.espares.co.uk
replace belt for model CJ4732600
that model number you sent isn't a good model number,your problem is under Whirlpool Ultimate Care II LSQ9549L Top Load Washer,if this...
washing machine not agitating
Hello, seanI am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend...
I have a Whirlpool ultimate 2 gas dryer Model
Hello, welcome to FixYa. I'll start by saying your post indicates it is obviously a Whirlpool gas dryer. If this is a symptom were the...
whirlpool ultimate care II noise
Hello, The number one thing wrong when that type top load washer makes noise is a broken coulper between the motor and the gearcase. This...
top load Ge washer model number WVSR1060A1ww will
There can be many reasons and i will do the best to cover everything that can happen with your washer to cause it from not draining or...
How hard is it to replace the switch that turns on
Hello, welcome to FixYa. The lid switch failure/breaking is definitely a common top load washer problem. Here`s how you can repair it pretty...
Washer will load and drain at the same time, hence
Hello Bobby, welcome to FixYa. I understand you have a Whirelpool topload washer, "will load and drain at the same time", correct...
Hi My whirlpool ultimate care 2
Hi First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the lid...
When I'm doing a load
sounds like a bad lid switch ...replace good luck
I have a Whirlpool Ultimate
You likely have either a folded cold inlet hose (squashed) or self plumbing tap that is rusted in the cutter so slow filling or a blocked...
ultimate care washer is very
Hello, The problem is going to be the water inlet valve..the solonoid for the cold water side is very weak and hardly opening. The water...
My washing machine (model LSB6300LWO)
Hello, It sounds like perhaps the motor coupler is broken..it is something that wears out and the 2 blankets didnt necessarly cause it but...
I have a whirlpool ultimate
This is very likely a problem with a broken drain pump especially when the leak starts as the machine fills. Another possible cause of the...
See all Whirlpool Ultimate Care II LSQ9549L Top Load Solutions
Unsolved Problems
I have followed cleaning procedures but it still...
Followed the regular cleaning instructions but still smelles
have a Whirlpool Superapacity Plus - 3357978 it...
Can you tell me how to take it apart and find and fix this issue
will not go through the spin cycle
the washing machine goes through all the cycles but the spin cycle
Whirlpool Washer smells burnt and wont empty.
I was washing one shirt on handwash cycle and now it wont empty and smells burnt. If I twist the knob it will agitate...
belt slips in final spin
no final spin
My agitator is not working as it should. I...
My agitator is not working as it should. I replaced the dogs, which were badly worn, and now the agitator moves, but not...
See all Whirlpool Ultimate Care II LSQ9549L Top Load Problems
Manuals & Guides
TopDo you have a manual for Whirlpool Ultimate Care II LSQ9549L Top Load Washer? - Upload it to FixYa!
Upload a manual for Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Specifications
TopKey Features
Full Product Name:Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer Type:Washer
Load Type:Top Load
Wash
Wash Presets:9 Wash Presets
Convenience
Additional Features:Quiet Operation
Dimensions
Overall Depth:25.5 in.
Overall Height:43 in.
Overall Width (Display):27 in.
Warranty
Warranty:1 Year Parts and Labor
What's your problem?
Fix-O-Meter
378,373
378,373 people have viewed this product
- 3,692 people asked about this product.
- 1,727 people found solutions for this product.
- 104 people have added this product.
Does your front...
Checking the...
Keep Washers...
