You can reset the router to factory default settings, press the reset button at the back of the router.
Please
note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE
LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you
get the connectivity, however, you have to make the connection secure
etc.
Reset the router to factory default setting, press and hold the
reset button for few seconds (It is at the back of the router near the DC Power Jack). The LEDs will then blink and the routers factory settings would be restored.
Please note that, after resetting the router you should be able to see
the router and connect to it via LAN Cable or Wirelessly as the router
automatic assigns the IP Address and gateway etc. Before proceeding to
the next step please make sure that you are getting the signals as well
as internet. However, the internet connection would not be secure, which
can be done later.
Now, all
you have to do is connect to the router and secure
the connection follow the following steps: -
First
you have to access the router through web browser (Internet Explorer)
by typing the IP address of your router in the address bar, which is
192.168.0.1 (Default router settings are written under the router) (unless you've configured otherwise, the default username is admin and the password "leave it blank") and lookup for the options to do the
following: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Setup"
2.Under "Wireless Security Mode", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback and approciate the efforts.
CreativeTECH
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
