Just follow the instructions and do it there will be no problem at all.First download
and install Pheonix from this link.Nokia
Phoenix Service Software 2011 - Download
secondly Download flash file from this link 5130 flash file and install it to C / program files/pheonix.. after
finished this installation open pheonix . Inside the interface at the> top
left <there you see "File"
click there and choose "open file" and then select the
approprait Product type i.e "which is written on the back panel
inside the battery of every Nokia(Type RM-000).After doing this again at
the left top count from "File"1..2..3..the 4th one is "Flashing"
press there, when you click there you'll see three sub-menus, just select the
"Firmware Update" again you'll see another interface. Look at
the product code there should be blank and put your "mouse tool" at
the straight end from the "Product Code" there is a Buttonand choose the code which is written in the back side of your phone. e.g CODE:0000000.if
the same code does not found just take one which is higher. After this you can
see "Dead phone USB flashing" click that box. Now this is the
last stage... Connect your phone with the USB to your PC and let
the driver install ...wait for a moment.(Ifyour phone working).Lastly after just finished (In case your
phone is Dead, unable to switch on in normal mode start from here)Connect the phone to pc without
powering...insert good battery and Click the "Referbish" button
after this, a message will prompt you "press power botton"
etc. insert charger orpress it and wait
until the phone will Restart automatically in normal mode 10-15 minutes. If you
cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good
luck
It is required to clear the temporary folder before downloading the Software. For this click 'Start' button then select 'Run' (you can open 'Run' by press and hold Windows button on the keyboard and then pressing alphabet key 'R'). Type '%temp%' inside the Run window, and you will get a folder opened. Delete all the files in the folder and close it. Now try to download the Software, it will work.
All the best.
