20 Most Recent LG Flatron M4715cg Commercial Grade 47"computer Monitor Questions & Answers
Hi, Sounds like an issue of the video card not the monitor. Take to computer shop to verify. One thing you can try is drop the dpi down (refresh rate)a bit. Then try again. If that makes sense to you. Hope that helps.
LG Flatron... | Answered on Feb 10, 2018
It´s not safe to anchor it to the plastic back, monitors usually have a metal frame inside that support the weight of the monitor.
LG Flatron... | Answered on Nov 12, 2017
Flatron l17175
what on earth is that?
ahhhhhh and LG, lucky Goldstart monitors. not HP.
wrong forum Ill move you.
LG Flatron... | Answered on Oct 16, 2017
Sounds like it has a CRT and the EHT is collapsing. Maybe a dry joint around the timebase output transformer.
LG Flatron... | Answered on Mar 18, 2017
You need to use a ESR meter to check capacitors
LG Flatron... | Answered on Mar 02, 2017
If you get half of the screen darker, remember that LCd monitor have 2 neon lamp at each extremity of the LCD, when one goes out you get this problem. it is possible to replace the LCD neon lamp, I did it many time, but you need to tear all the monitor appart and be carefull not to break any glass while doing so.
LG Flatron... | Answered on Aug 22, 2016
Settings.... Wireless
LG Flatron... | Answered on Jun 23, 2016
are you in dual screen mode on a laptop possibly? Check that the laptop is dual enabled so that it is either an extension or a duplication of your main screen. This is common mistake in setting up external monitor on laptop.
LG Flatron... | Answered on Apr 10, 2015
you need to look at the geometry settings on the video driver on your computer to find the right set for your monitor. There is some adjustment in your monitor to choose 4:3 or 16:9, but in PC mode this is usually over-riden though.
check your VGA cable and connector that it is securely connected. Sounds like the blue is open or disconnected. If not, the video card on the PC or the receiving card in the monitor is going out,
Don't forget to adjust your setting on the computer as well.
LG Flatron... | Answered on Feb 09, 2015
LG Flatron M4715cg Commercial Grade 47"computer Monitor Logo
Popular Tags
2 questions posted
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Flatron LG
  • Flatron LG
Most Popular Question
subtle two toned split screen color
  • Computers & Internet
