SOURCE: Whirlpool Ultimate Care Heavy Duty Washer will not spin
It sounds like you have a broken motor coupling. This is a very inexpensive and simple repair.
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
SOURCE: ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
SOURCE: I have a Whirlpool Ultimate Care II (heavy duty).
possible motor coupler broken but it should still drain but nothing else
SOURCE: Hello. We have a Whirlpool Ultimate Care Heavy
yes you r. lol
the agit. dogs need replaced look in your phone book 4 a dealer near you to get this part you need. remove softner despenser and inner cap then you will need to remove bolt 7/16th or 3/8th after removing bolt pull up on agit.it is 2 pc if it all comes out as one pc. ok you need to stand on lower 1/2 and pull up you now have the top pc in your hands. you will see some type of cup that holds in the dogs remove by flipping up side down install new parts and put back togther a small tip use the bolt
to put cup back in when you are ready to put back together put top pc of agit. over cup up side down you will need to line up with 2 or 4 ears on bottom pc. it should click now reinstalle sound hard but very easy just keep preassur on dog cup at all time with bolt and socket have fun
SOURCE: Find serial and model number
Hello. for a top loader look here
