To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
To make it to factory reset, you have to enter its Service Mode option; and select Factory Reset [System reset].
i turned on my ps3 and it goes itself on safe mode.I tryied to turn off and on but same thing and i dont have ds3 how can i repair it?Is it corrupted or...is it deleted PLS SOMEONE ANSWER :(
Power On. Then press and hold until it shuts down again. Now press and hold the power button until you hear....1 beep..... then 2 beeps....release. This will put you in the service mode. Select option to reset system to factory settings.
Factory on screen means that the TV is stuck in service mode (Durabrand
and more). The problem is fixed accessing Service mode and resetting to
factory default settings.
On Durabrand TVs problem is fixed using a programmable remote, entering service code on remote, and accessing service menu. Procedure is listed on TV service manual.Most durabrand use Menu and key combination 683 to access service mode. If that does not work, calll manufacturer number to get the key sequence to enter factory menu.
