I changed input from HDMI 1 to DVD. After DVD use, I attempted to change back to HDMI 1 but am...
(More)
I changed input from HDMI 1 to DVD. After DVD use, I attempted to change back to HDMI 1 but am unable to do so. What I have is a Screen full of snow and when I press the input button I can see TV and the station number highlighted in green color. The TV and station number remains on a few seconds then disappears. I am using the press-button on the side of the LCD. Help? No luck with the remote as well. The model is P50HDTV10A.
how do I get to see the 2nd rgb screen. I want to hook up my laptop. I have the proper cables.I...
(More)
how do I get to see the 2nd rgb screen. I want to hook up my laptop. I have the proper cables.I have gone to the DTV screen but it will not see it.
i have a vizio tv p50hdm it doesn't show nothing the screen is so dim i have audio, i t was working...
(More)
i have a vizio tv p50hdm it doesn't show nothing the screen is so dim i have audio, i t was working fine,i was watching tv and i heard that blew something behindand the screen goes off like a shadow aud the audio worked can you tell me what board i have to replace y or z thanks for your help
50in vizio plasma not turning on after unplugging it.Took the tv off the wall to move it and when I...
(More)
50in vizio plasma not turning on after unplugging it.Took the tv off the wall to move it and when I plugged it back in it will not turn on
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
